[OpenFOAM.org] Getting Started: mkdir missing operand
Old   October 31, 2014, 06:18
Default Getting Started: mkdir missing operand
sisi is on a distinguished road
I have exactly the same problem:
mkdir -p $FOAM_RUN
Error:
mkdir: missing operand
Try `mkdir --help' for more information.
How to declare the variable???
FOAM_RUN=run
sisi is offline   Reply With Quote
Old   October 31, 2014, 08:07
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
variable FOAM_RUN is defined on line 204 of $WM_PROJECT_DIR/etc/config/settings.sh file.
If yours is empty, it seems you've forgotten to set up environment with
$ source <path to your OpenFOAM installation>/etc/bashrc
alexeym is offline   Reply With Quote
Old   October 31, 2014, 09:40
Thanks! I need to learn more about OpenFOAM Environment Variables. That did solve my problem:
source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
Old   May 31, 2018, 19:58
Default mkdir: missing operand
Chris Harding
HappyS5 is on a distinguished road
I am new to OpenFOAM and Ubuntu.
When I try to do the following:
mkdir -p $FOAM_RUN
I get the following error:
Try 'mkdir --help' for more information.
Can someone help me please. Remember, I am new to OpenFOAM and UBuntu. So please be detailed with your help.
HappyS5 is offline   Reply With Quote
Old   June 1, 2018, 16:25
Retired Super Moderator
Bruno Santos
Quick question/answer: Knowing which version of OpenFOAM and Ubuntu, as well as which installation instructions you've followed, would make it easier to diagnose the problem.
So, I'll try guessing that you installed OpenFOAM 5 Deb package(s) on Ubuntu 16.04 or 17.10, in which case, you will need to run the following command to activate this version of OpenFOAM:
source /opt/openfoam5/etc/bashrc
For more details, read the respective version's section "User Configuration" here: https://openfoam.org/download/5-0-ub...-configuration
Then you should be able to run the command:
mkdir -p $FOAM_RUN
without any problems... or at least I hope so, unless something went wrong during the installation.
Solver for FSI strongly coupled charbel OpenFOAM Programming & Development 58 December 7, 2016 21:31
[OpenFOAM] Xlib: extension "GLX" missing on display goldbeard ParaView 5 March 24, 2013 13:12
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 07:43
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
