[OpenFOAM.org] gcc: error: unrecognized command line option '--showme:link'
Like Tree4Likes
  • 2 Post By alexeym
  • 2 Post By mbcx4jc2
Old   February 9, 2015, 09:14
Default gcc: error: unrecognized command line option '--showme:link'
James
mbcx4jc2 is on a distinguished road
I'm running Ubuntu 14.04 LTS 64-bit. Having followed the instructions on the Ubuntu Deb Pack Installation, I came across the error:
However, doing
sudo update-alternatives --list mpi
Give
/usr/lib/openmpi/include
instead of what the instructions suggest is the cause of the problem (i.e. that the output should be /usr/mpich/include if MPICH is installed).
Doing
sudo update-alternatives --set mpi /usr/lib/openmpi/include
Obviously achieves nothing as it's already correctly set.
Doing
which mpicc
gives a clue:
~/anaconda/bin/mpicc
which suggests that my installation of anaconda is causing some conflicts.
Any ideas? Many thanks!
mbcx4jc2 is offline   Reply With Quote
Old   February 9, 2015, 10:18
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It seems Anaconda uses MPICH2 instead of OpenMPI. So, you can try following this thread: http://www.cfd-online.com/Forums/ope...me-errors.html.
mbcx4jc2 and aow like this.
alexeym is offline   Reply With Quote
Old   February 9, 2015, 10:39
James
Originally Posted by alexeym View Post
Thanks for the reply.
For anyone stumbling on this problem, I followed the instructions in the link supplied above which involved putting a file called "pref.sh" in /opt/openfoam231/etc/ which contains the line:
export WM_MPLIB=OPENMPI
This solved the problem.
aow and zweihuehner like this.
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
