[foam-extend.org] paraFoam not working in Foam-extended 3.2
Old   December 19, 2016, 15:22
Default paraFoam not working in Foam-extended 3.2
Osman is on a distinguished road
I am a newbie in the forum. I have installed foam-extended-3.2 in Ubuntu 16.04 version. Everything is going fine. I have done meshing and also run the simulation perfectly (I was doing cavity tutorial of incompressible icoFoam cases). Then, while I was writing 'paraFoam &' command in the terminal, paraview is opening but, shutting down instantly, showing the following message in the terminal:
created temporary 'cavity.OpenFOAM'
Read float past end of buffer
ERROR: In /build/paraview-arsa8T/paraview-5.0.1+dfsg1/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 310
vtkSISourceProxy (0x4937e30): Failed to create vtkXdmfReader. Aborting for debugging purposes
Can someone say, what's the problem? I followed this link (https://openfoamwiki.net/index.php/I...oam-extend-3.2) for installation. Thanks.
Osman is offline   Reply With Quote
Old   December 27, 2016, 11:44
Retired Super Moderator
Bruno Santos
Quick questions:
  1. What does the following command give you?
    which paraview
  2. Did you install ParaView manually or was it built by the script "Allwmake.firstInstall"?
  3. What is the content of the file "etc/prefs.sh"? You can check by running:
    foam
    cat etc/prefs.sh
Old   January 3, 2017, 18:11
First I want to apologize for my late response as I was out for holiday.
1.
/usr/bin/paraview
2. I am not sure about it. But, before installing foam-extend-3.2, I installed Openfoam 4.0. ParaFoam is perfectly working for OF 4.0.
3.
export WM_THIRD_PARTY_USE_BISON_27=1
export QT_BIN_DIR=/usr/bin/qmake
export QT_BIN_DIR=/usr/bin/qmake-qt4
Old   May 25, 2017, 20:39
Metikurke
Metikurke is on a distinguished road
I am also facing the same problem while using the foam extend 4.0. I have tried everything possible, I have also checked my installation comletely, and tried finding solutions in the forum. But no where it has been discussed. The error report as follows,
/Work/tutorials/incompressible/icoFoam/cavity$ ERROR: In /build/paraview-arsa8T/paraview-5.0.1+dfsg1/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 310
vtkSISourceProxy (0x4304c10): Failed to create vtkXdmfReader. Aborting for debugging purposes.
[1]+ Aborted (core dumped) paraview
It would be really great if you can give me the solution.
Thank you
Metikurke is offline   Reply With Quote
Old   May 26, 2017, 05:07
Metikurke
With Regard to above problem tried running, paraview a.foam now its working properly.
Old   November 30, 2017, 11:55
James Gross
jgross is on a distinguished road
Osman, I am having the same issue. I had installed Paraview with OpenFOAM 5 previously before installation of Foam Extend 4.0. When I type the above commands, I receive the same message as you.
/usr/bin/paraview
and
export QT_BIN_DIR=/path/to/qmake_directory
export CUDA_ARCH=sm_30
Did you ever manage to get ParaFOAM working with Foam Extend 4.0?
Thank you.
jgross is offline   Reply With Quote
Old   December 5, 2017, 06:39
James Gross
I managed to fix it so that paraFoam command works with extend-4.0. I achieved this by modifying the PARAVIEW_DIR in the foam folder such that it calls the Paraview that was installed during extend-4.0 installation, rather than the newer version of Paraview from the previous OpenFOAM 5.0 installation.
Some of the details of this procedure were found online, but I can't seem to find a link for it right now. I hope this helps people that may have this issue in the future.
James
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 04:14
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 29, 2015 23:42
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
