[OpenFOAM.com] "OpenCFD-OpenFOAM4WindowsInstaller-v1906.exe" installation issue
Old   August 21, 2019, 04:13
Default "OpenCFD-OpenFOAM4WindowsInstaller-v1906.exe" installation issue
philip lu
philiplu is on a distinguished road
I'm new in "OF" and installing
"OpenCFD-OpenFOAM4WindowsInstaller-v1906.exe" on Win7-computer following the guidelines in
"README.TXT" or "OF_Windows_Guide_v1906.pdf"(inside the above installation-"exe")
which looks like: after installation, in Desktop clicking "OF_Create_Env"(mandatory in first time), then "OpenFOAM_Start" would enable working with OF.
but the same msg. always came out after installations:
"...this computer doesn't have VT-X/AMD-v enabled ..."
in fact I'd enabled "VT" in the BIOS before installation.
do you know what or where is wrong?
thank you in advance and sorry for my teething question
(btw. "havdetectiontool.exe" checked my computer, i.e. VT is enabled)
thank you again
philiplu is offline   Reply With Quote
Old   August 21, 2019, 10:09
Carlo_P
Carlo_P is on a distinguished road
Hey Philip,
I had also some troble in installing OpenCFD in Windows.
If you have the possibility, try to use OpenFOAM4Windows for CFDSupport.
https://www.cfdsupport.com/openfoam-for-windows.html
I'm using it and without having problems.
Cheers,
Carlo
Carlo_P is offline   Reply With Quote
Old   August 21, 2019, 19:57
philip lu
hello Carlo,
thanks for your reply
kind regards
Philip
Originally Posted by Carlo_P View Post
Hey Philip,
Cheers,
Carlo
[swak4Foam] swak4Foam 0.4.2 with foam-extend-4.1 Installation Issue treem22 OpenFOAM Community Contributions 6 May 9, 2022 08:05
how do i fix installation error of ansys 19.0 on ubuntu 18.04 rid_taki ANSYS 15 June 7, 2021 06:32
[OpenFOAM.org] Non-root installation of OpenFOAM 2.4.x, parallel issue syavash OpenFOAM Installation 12 March 4, 2019 07:15
[OpenFOAM.org] Installation issue - CGAL/Delaunay_triangulation_3.h lost.identity OpenFOAM Installation 10 December 15, 2016 08:10
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
