[OpenFOAM.com] "OpenCFD-OpenFOAM4WindowsInstaller-v1906.exe" installation issue |
August 21, 2019, 04:13 |
philip lu
Rep Power: 6 |
I'm new in "OF" and installing "OpenCFD-OpenFOAM4WindowsInstaller-v1906.exe" on Win7-computer following the guidelines in "README.TXT" or "OF_Windows_Guide_v1906.pdf"(inside the above installation-"exe") which looks like: after installation, in Desktop clicking "OF_Create_Env"(mandatory in first time), then "OpenFOAM_Start" would enable working with OF. but the same msg. always came out after installations: "...this computer doesn't have VT-X/AMD-v enabled ..." in fact I'd enabled "VT" in the BIOS before installation. do you know what or where is wrong? thank you in advance and sorry for my teething question (btw. "havdetectiontool.exe" checked my computer, i.e. VT is enabled) thank you again |
August 21, 2019, 10:09 |
Carlo_P
Rep Power: 7 |
Hey Philip,
I had also some troble in installing OpenCFD in Windows. If you have the possibility, try to use OpenFOAM4Windows for CFDSupport. https://www.cfdsupport.com/openfoam-for-windows.html I'm using it and without having problems. Cheers, Carlo |
August 21, 2019, 19:57 |
#3 | |
philip lu
Rep Power: 6 |
hello Carlo,
thanks for your reply kind regards Philip Quote:
[swak4Foam] swak4Foam 0.4.2 with foam-extend-4.1 Installation Issue | treem22 | OpenFOAM Community Contributions | 6 | May 9, 2022 08:05 |
how do i fix installation error of ansys 19.0 on ubuntu 18.04 | rid_taki | ANSYS | 15 | June 7, 2021 06:32 |
[OpenFOAM.org] Non-root installation of OpenFOAM 2.4.x, parallel issue | syavash | OpenFOAM Installation | 12 | March 4, 2019 07:15 |
[OpenFOAM.org] Installation issue - CGAL/Delaunay_triangulation_3.h | lost.identity | OpenFOAM Installation | 10 | December 15, 2016 08:10 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
