[OpenFOAM.org] Questions about using the tutorials for OpenFOAM 5.0 on Ubuntu 16.04.3
Old   February 10, 2018, 23:35
Post Questions about using the tutorials for OpenFOAM 5.0 on Ubuntu 16.04.3
Patrick Isherwood
pisherwood is on a distinguished road
So I don't have much background with linux so please bear with me. I installed set up a dual boot of ubuntu 16.04.3 on my windows 10 laptop and have attempted to install OpenFOAM. I was able to install OpenFOAM but from what I gather I need to give my user access to the root directory since I have installed it in the opt directory. I couldn't edit or execute the files because they were in a root directory so I moved the tutorials to the home directory. I can now edit the files but wen i run OpenFOAM commands it gives me a 'command cannot be found' error when i try and run a simulation.
my question:
1. is there a easy safe way I can get access to the root directory as a standard user
2. is there an easy way to simply install openfoam in the home directory so I don't have to have root access to access the files
3. is there a piece of this that I am just not understanding (i honestly assume this has to be part of my problem)
again im real new to this. Thanks!!
pisherwood is offline   Reply With Quote
Old   February 12, 2018, 15:51
Retired Super Moderator
Bruno Santos
Quick question: Which installation instructions did you follow?
Old   February 12, 2018, 16:45
Patrick Isherwood
I used these, as far as i know this is the most basic way
https://openfoam.org/download/5-0-ubuntu/
Old   February 12, 2018, 16:51
Bruno Santos
Quick answer: Then you don't need to worry about the files having been installed at "/opt". That installation will by default be available for any normal user.
If you run the following command:
ls -ld /opt/openfoam5
you should see the following:
drwxr-xr-x 10 root root 4096 Nov  5 23:11 /opt/openfoam5/
Which states that "root" (the first "rwx"), "group" (the first "r-x") and "others" (the second "r-x"), all have reading (r) and execution (x) permissions.
This means that as a normal user, you should be able to use OpenFOAM without problems. All you need to do is execute the following command as a normal user, in order to be able to run OpenFOAM's applications:
source /opt/openfoam5/etc/bashrc
In other words, follow the instructions given here: https://openfoam.org/download/5-0-ub...-configuration - section "User Configuration", follow them as a normal user and everything should work as intended. Then keep reading the instructions and it should work properly, without any additional root powers .
Old   May 27, 2018, 12:57
CFDpal
CFDpal is on a distinguished road
It is also a good idea to copy some templates (tutorials) into some RUN directory. Then run applications in the run directory. In this case, you would always have ability go back.
CFDpal is offline   Reply With Quote
command not found, istallation help, opefoam, root access, ubuntu
[OpenFOAM.org] I have trouble installing openfoam 5.0 on ubuntu 16.04 haydii OpenFOAM Installation 5 December 27, 2018 10:56
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 5, 2018 23:48
[waves2Foam] Questions about wave2Foam tutorials TXQ OpenFOAM Community Contributions 5 January 10, 2018 01:41
[foam-extend.org] foam-extend 3.2 on Ubuntu 12.04, Floating point exception for tutorials arsalan.dryi OpenFOAM Installation 7 November 14, 2016 17:33
Simple questions regarding CCM+ tutorials daniel1030 STAR-CCM+ 2 December 28, 2014 00:03
