[OpenFOAM.org] OpenFOAM 4.0 installation in CAELinux 2013
Old   February 15, 2018, 07:53
Default OpenFOAM 4.0 installation in CAELinux 2013
Leelakrishnan
leee is on a distinguished road
Send a message via Skype™ to leee
I am trying to upgrade from the OpenFOAM2.1.1 and Helyx OS 1.0.1 to OF4.0 and Helyxos 2.4. I have installed the latest version of Helyx OS but i couldn't able to install the OpenFOAM. When i tried to do that i received an error "the installer cant run in openfoam environment. Please use a fresh terminal without openfoam environment".
Please help me out of it. Thanks in advance.
regards,
Leelakrishnan
leee is offline   Reply With Quote
Old   February 24, 2018, 18:18
Retired Super Moderator
Bruno Santos
Quick answer: You need to replace the source lines you have in the file "~/.bashrc", with the the respective alias alternatives.
For example, if you have this:
. $HOME/OpenFOAM/OpenFOAM-4.0/etc/bashrc
you need to replace it with:
alias of40='. $HOME/OpenFOAM/OpenFOAM-4.0/etc/bashrc'
If you still have a similar line for OpenFOAM 2.1.1, you need to do something similar as well.
Then save the file "~/.bashrc" with this changed.
Then start a new terminal window/tab. Now you can start up Helyx-OS.
Next time you need to use OpenFOAM 4.0 or 2.1.1, you can activate it by running the respective alias, for example, by running:
of40
For more details: https://openfoamwiki.net/index.php/I...ment_Variables
helyx-os, installation problem, openfoam4.0
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 04:29
Source Pack Installation OpenFOAM Version 2.1.0 on Redhat Linux Indrajit OpenFOAM Installation 1 April 1, 2012 04:39
OpenFOAM 1.7.1 installation problem on Fedora 14 armonica OpenFOAM Installation 16 March 31, 2011 13:16
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 02:15
