[OpenFOAM.org] OpenFOAM 4.0 installation in CAELinux 2013 |
February 15, 2018, 07:53 |
I am trying to upgrade from the OpenFOAM2.1.1 and Helyx OS 1.0.1 to OF4.0 and Helyxos 2.4. I have installed the latest version of Helyx OS but i couldn't able to install the OpenFOAM. When i tried to do that i received an error "the installer cant run in openfoam environment. Please use a fresh terminal without openfoam environment".
Please help me out of it. Thanks in advance. regards, Leelakrishnan |
February 24, 2018, 18:18 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: You need to replace the source lines you have in the file "~/.bashrc", with the the respective alias alternatives.
For example, if you have this: Code:
. $HOME/OpenFOAM/OpenFOAM-4.0/etc/bashrc Code:
alias of40='. $HOME/OpenFOAM/OpenFOAM-4.0/etc/bashrc' Then save the file "~/.bashrc" with this changed. Then start a new terminal window/tab. Now you can start up Helyx-OS. Next time you need to use OpenFOAM 4.0 or 2.1.1, you can activate it by running the respective alias, for example, by running: Code:
of40
helyx-os, installation problem, openfoam4.0 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
OpenFOAM 1.7 installation on Redhat linux | maxims | OpenFOAM Installation | 2 | November 30, 2012 04:29 |
Source Pack Installation OpenFOAM Version 2.1.0 on Redhat Linux | Indrajit | OpenFOAM Installation | 1 | April 1, 2012 04:39 |
OpenFOAM 1.7.1 installation problem on Fedora 14 | armonica | OpenFOAM Installation | 16 | March 31, 2011 13:16 |
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 | superfxfund | OpenFOAM Installation | 3 | November 11, 2010 02:15 |
