[OpenFOAM.org] Problem compiling ParaView-3.12.0 on OpenFOAM-2.2.x
Like Tree1Likes
  • 1 Post By charles4allme
Old   May 23, 2018, 09:48
Default Problem compiling ParaView-3.12.0 on OpenFOAM-2.2.x
charles4allme is on a distinguished road
I am using an Ubuntu 16.04. I am trying to compile ParaView-3.12.0 on OpenFOAM-2.2.x and I get these errors. I have also attached the log file. I have seen similar issues on here but with different versions of ubuntu and OPenFOam.
CMake Warning at CMakeLists.txt:110 (MESSAGE):
  Warning: You are using Qt 4.8.7.  Officially supported version is Qt 4.6
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
OPENGL_gl_LIBRARY (ADVANCED)
    linked by target "vtkVolumeRendering" in directory /home/okorie/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/VTK/VolumeRendering
    linked by target "vtkWidgets" in directory /home/okorie/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/VTK/Widgets
    linked by target "vtkParallel" in directory /home/okorie/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/VTK/Parallel
    linked by target "vtkPVVTKExtensions" in directory /home/okorie/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/ParaViewCore/VTKExtensions
    linked by target "PointSprite_Rendering" in directory /home/okorie/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/Plugins/PointSprite/Rendering
make: *** No targets specified and no makefile found.  Stop.
Command exited with non-zero status 2
0.00user 0.00system 0:00.00elapsed 0%CPU (0avgtext+0avgdata 2384maxresident)k
0inputs+0outputs (0major+139minor)pagefaults 0swaps
make: *** No rule to make target 'install'.  Stop.
Best regards,
charles
charles4allme is offline   Reply With Quote
Old   May 26, 2018, 16:51
Retired Super Moderator
Bruno Santos
Quick question: Did you try following the instructions given here: https://openfoamwiki.net/index.php/I...u#Ubuntu_15.10 ?? Because in step #12.2 is the hack needed for building ParaView 3.12.0 with more modern Ubuntu versions.
Old   May 29, 2018, 07:30
Hi wyldckat,
Many thanks for the advice. I tried it and it worked.
Best regards,
charles
wyldckat likes this.
[OpenFOAM.org] Problem compiling PV4Readers into OpenFOAM 2.4.0 Spurius OpenFOAM Installation 0 November 14, 2018 09:05
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 05:48
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) sfigato OpenFOAM Installation 22 January 31, 2013 10:16
[swak4Foam] Problem with compiling funkySetFields in OpenFOAM 2.1. sfigato OpenFOAM Community Contributions 1 January 17, 2013 12:22
