[OpenFOAM.org] Paraview 4.1 to 4.4 fails to run on Ubuntu 19.04 |
May 19, 2019, 14:56 |
Daniel
Rep Power: 21 |
Hello
I have managed to successfully build OpenFOAM-2.4.0 on Ubuntu 19.04. However I have a problem with paraview. It does compile without any problem, but when I execute paraFoam command the following error appears and paraview never opens: Code:
created temporary 'depthCharge2D.OpenFOAM' libGL error: MESA-LOADER: failed to open radeonsi (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri) libGL error: failed to load driver: radeonsi libGL error: MESA-LOADER: failed to open radeonsi (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri) libGL error: failed to load driver: radeonsi libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri) libGL error: failed to load driver: swrast X Error: GLXBadContext 158 Extension: 152 (Uknown extension) Minor opcode: 6 (Unknown request) Resource id: 0x2e000c2 X Error: BadValue (integer parameter out of range for operation) 2 Extension: 152 (Uknown extension) Minor opcode: 3 (Unknown request) Resource id: 0x0 ERROR: In /home/shadowfax/OpenFOAM/ThirdParty-2.4.0/ParaView-4.4.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx, line 633 vtkXOpenGLRenderWindow (0x1db4c90): Cannot create GLX context. Aborting. Aborted (core dumped) Code:
https://ufile.io/jvsd0a6y Regards, D. Khazaei |
June 16, 2019, 15:37 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: It looks like it might be a bug in Mesa: https://forum.manjaro.org/t/mesa-19-...2-issues/81217
Since it's been a month since you asked, perhaps this bug is already solved after updating Ubuntu 19.04?
June 21, 2019, 13:45 |
#3 | |
Daniel
Rep Power: 21 |
Thank you for the replay. My Ubuntu 19.04 installation is up to date, but unfortunately the problem is still there... Already tried latest mesa from https://launchpad.net/~paulo-miguel-...ve/ubuntu/mesa with no luck. |
[OpenFOAM] Paraview on Ubuntu | Tobi | ParaView | 1 | September 27, 2013 19:03 |
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message | peteryuan | OpenFOAM Installation | 6 | August 18, 2013 18:00 |
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 | wyldckat | OpenFOAM Installation | 14 | February 12, 2013 04:43 |
paraview doesn't run after upgrading to jaunty | lions85 | OpenFOAM | 8 | June 24, 2009 17:49 |
[OpenFOAM] Could anyone please help me in running the paraview in my Ubuntu system | chanduksekhar | ParaView | 2 | February 6, 2006 09:13 |
