[OpenFOAM.org] Paraview 4.1 to 4.4 fails to run on Ubuntu 19.04
Old   May 19, 2019, 14:56
Default Paraview 4.1 to 4.4 fails to run on Ubuntu 19.04
Daniel
Daniel_Khazaei will become famous soon enough
Hello
I have managed to successfully build OpenFOAM-2.4.0 on Ubuntu 19.04. However I have a problem with paraview.
It does compile without any problem, but when I execute paraFoam command the following error appears and paraview never opens:
created temporary 'depthCharge2D.OpenFOAM'
libGL error: MESA-LOADER: failed to open radeonsi (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
libGL error: failed to load driver: radeonsi
libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
libGL error: failed to load driver: swrast
X Error: GLXBadContext 158
  Extension:    152 (Uknown extension)
  Minor opcode: 6 (Unknown request)
  Resource id:  0x2e000c2
X Error: BadValue (integer parameter out of range for operation) 2
  Minor opcode: 3 (Unknown request)
  Resource id:  0x0
ERROR: In /home/shadowfax/OpenFOAM/ThirdParty-2.4.0/ParaView-4.4.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx, line 633
vtkXOpenGLRenderWindow (0x1db4c90): Cannot create GLX context.  Aborting.
Aborted (core dumped)
I have also attached the paraview build log here:
https://ufile.io/jvsd0a6y
Any help would be appreciated
Regards,
D. Khazaei
Daniel_Khazaei is offline   Reply With Quote
Old   June 16, 2019, 15:37
Retired Super Moderator
Bruno Santos
Quick answer: It looks like it might be a bug in Mesa: https://forum.manjaro.org/t/mesa-19-...2-issues/81217
Since it's been a month since you asked, perhaps this bug is already solved after updating Ubuntu 19.04?
Old   June 21, 2019, 13:45
Daniel
Thank you for the replay.
My Ubuntu 19.04 installation is up to date, but unfortunately the problem is still there...
Already tried latest mesa from https://launchpad.net/~paulo-miguel-...ve/ubuntu/mesa with no luck.
[OpenFOAM] Paraview on Ubuntu Tobi ParaView 1 September 27, 2013 19:03
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 18:00
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 04:43
paraview doesn't run after upgrading to jaunty lions85 OpenFOAM 8 June 24, 2009 17:49
[OpenFOAM] Could anyone please help me in running the paraview in my Ubuntu system chanduksekhar ParaView 2 February 6, 2006 09:13
