[Other] Foam-Extend with existing OpenFoam
Like Tree1Likes
  • 1 Post By sujay3101
Old   June 12, 2019, 15:22
Post Foam-Extend with existing OpenFoam
Sujay
sujay3101 is on a distinguished road
New user here, not sure of correct terminology.
I have been using openfoam for some weeks. Now I need to install foam extend.
I'm trying to solve some issues with the installation.
1. Is it possible/ recomended to install foam extend on a system where openfoam is already installed?
2. If yes, when we execute a command, for example pisoFoam, how do we know if the command is executed by openfoam or foam extend?
sujay3101 is offline   Reply With Quote
Old   June 24, 2019, 07:49
Andreas P.
AndreasPe is on a distinguished road
Everytime you start the console, you have to source the bashrc file of the openFOAM/foam-extend version you want to use by typing
source /*openFoamInstallationFolder*/etc/bashrc
Only then you are able to use the compiled applications.
You should always just source a bashrc file of one version at a time in order to ensure you are using only applications from this specific version.
AndreasPe is offline   Reply With Quote
Old   June 24, 2019, 16:04
Retired Super Moderator
Bruno Santos
Quick note: You can also use aliases, namely a command that allows you to activate a specific environment, as instructed here: https://openfoamwiki.net/index.php/I...nFOAM_versions
Old   June 29, 2019, 06:57
Sujay
Thanks! I have been able to use both with the help of aliases.
wyldckat likes this.
foam-extend-4.0, linux, openfoam
Difference between OpenFOAM and FOAM extend ce73stargazer OpenFOAM 9 November 10, 2019 10:00
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 07:53
