[OpenFOAM.org] Installation on Ubuntu Subsytem - Failed to fetch |
June 28, 2019, 11:52 |
Semih
Rep Power: 9 |
Hello everyone,
Manytimes, I installed OpenFoam on my home computer and office pc. However, nowadays I can not re-install OpenFoam on my home pc. I tried everything and look at every forum. But I could not solve the problem. While I tried to install OF, I follow the instructures. But after, sudo apt-get update; I write the sudo apt-get -y install openfoam6 and I get this: Code:
E: Failed to fetch https://netix.dl.sourceforge.net/pro...0620_amd64.deb Could not handshake: The TLS connection was non-properly terminated. [IP: 87.121.121.2 443] E: Failed to fetch https://netix.dl.sourceforge.net/pro...0221_amd64.deb Could not handshake: The TLS connection was non-properly terminated. [IP: 87.121.121.2 443]E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? Code:
Need to get 153 MB/318 MB of archives. After this operation, 1929 MB of additional disk space will be used. Get:3 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libgstreamer1.0-0 amd64 1.14.4-1~ubuntu18.04.1 [862 kB]Err:1 https://netix.dl.sourceforge.net/pro...am/foam/ubuntu bionic/main amd64 openfoam6 amd64 20190620 Could not handshake: The TLS connection was non-properly terminated. [IP: 87.121.121.2 443] Err:2 https://netix.dl.sourceforge.net/pro...am/foam/ubuntu bionic/main amd64 paraviewopenfoam56 amd64 0-20190221 Could not handshake: The TLS connection was non-properly terminated. [IP: 87.121.121.2 443] Get:4 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libgstreamer-plugins-base1.0-0 amd64 1.14.4-1ubuntu1.1~ubuntu18.04.1 [684 kB] Get:5 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-libc-dev amd64 4.15.0-54.58 [1004 kB] Get:6 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 gstreamer1.0-plugins-base amd64 1.14.4-1ubuntu1.1~ubuntu18.04.1 [585 kB] Fetched 3136 kB in 12s (257 kB/s) Last edited by wyldckat; July 9, 2019 at 18:55. Reason: Added [CODE][/CODE] markers |
July 9, 2019, 18:56 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: After a quick search for:
ubuntu wsl Could not handshake: The TLS connection was non-properly terminated.
August 3, 2019, 10:45 |
#3 | |
Semih
Rep Power: 9 |
October 7, 2020, 14:06 |
Vijay
Rep Power: 6 |
I am getting the same error. Do I need to restart the process of installation from beginning or do we have any other solution? Please help
October 8, 2020, 07:58 |
Petros Ampatzidis
Rep Power: 7 |
The error related to the initial post was due to the fact that an antivirus tool was blocking the installation. If this is not the case for you, clean everything and restart the installation following step by step the respective guides. See here. Best, Petros |
October 8, 2020, 13:26 |
Vijay
Rep Power: 6 |
Thank you for reply. The error was due to bad network. But I restarted the process by entering:
sudo apt-get update sudo apt-get -y install openfoam8 and it worked |
June 17, 2021, 14:40 |
Manaf Muhammed
Rep Power: 7 |
First Uninstall the OpenFOAM
https://askubuntu.com/questions/1246...g-from-openfoa sudo apt-get clean Then try Using 1. sudo apt-get update 2. sudo apt-get upgrade Then try to reinstall Openfoam |
err, openfoam6, windows 10 |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
