May 23, 2010, 05:58 |
OpenFOAM-dev Live USB DVD, based on kubuntu
Henrik Rusche
Rep Power: 18 |
the USB-Stick-Team (Oliver Borm, Bernhard Gschaider, Henrik Rusche) proudly presents the release candiate of this year's OpenFOAM Workshop-USB-Stick. It is a continuation is last year's effort discussed in http://www.cfd-online.com/Forums/ope...lax-based.html We tried to build on that experience and the helpful comments - thank you! The image is based on Kubuntu 10.04 and currently includes OpenFOAM 1.5-dev r1726 (including PyFoam, cgnstools, funkySetFields, groovyBC and simpleFunctionObjects), paraview with Takuya's OpenFOAM reader, enGrid, Open CASCADE, calculix, netgen, blender, freecad, octave, yacas. The full manifest can be found in casper/filesystem.manifest casper/filesystem.manifest-desktop How do I get my fingers dirty? There are several ways! 1) Use usb-creator-* to extract the iso onto the stick. Note that you can use other software (such as unetboot), but not all of them create the persistant storage file. Then change the boot order and reboot the machine. 2) Unpack the tgz (contains a 256 Mb persistant storage file) onto the stick and run either boot/bootinst.sh or boot/bootinst.bat - Just like we did with SLAX. Then change the boot order and reboot the machine. 3) Boot the iso within a VirtualBox or similar software - no persistant storage, but you should be able to mount shares and disks that you connect to the VirtualBox. Don't think anybody has tried this, yet . 4) Make a stick using options 1 or 2 and boot it within a VirtualBox. More detailed instructions can be found here http://web.student.chalmers.se/groups/ofw5/Instr.htm Where do I get the iso or tgz? Download OpenFOAM_kubuntu.iso (md5sum: 0ae471daf7f748f3cde7b1937ac86465) OR OpenFOAM_kubuntu.tgz (md5sum: 6f8df60add546c0d390d24fc14290d7f) from http://sourceforge.net/projects/openfoam-extend/files/ A few things you should know
How to test? Please test your favorite application, not just the cavity - We have done that . Most of the non-OpenFOAM packages have not even been started so please give them a spin. How is it done? The compilation is based on the Ubuntu packages which may be downloaded individually from https://launchpad.net/~cae-team/+archive/ppa?field.series_filter=lucid Best Regards, Henrik Last edited by henrik; May 23, 2010 at 06:19. Reason: add md5sum |
May 31, 2010, 12:46 |
Hi Henrik,
where can I get the "OpenFOAM 1.5-dev r1726" version and what other files do i need to download and compile for a fully operational version? thx & regards! |
May 31, 2010, 16:04 |
Henrik Rusche
Rep Power: 18 |
Dear Heavy User,
1. You need usb-creator-* or similar to make a bootable USB stick out of the iso. OR 2. You need nothing to make a bootable stick out og the tgz. OR 3. You need your favourite burning to tool to make a CD out of the iso. For 1 and 2, please follow the instructions written down here: http://web.student.chalmers.se/groups/ofw5/Instr.htm Henrik |
June 1, 2010, 08:05 |
Hi Henrik,
thanks for your quick reply! Unfortunately I have a notebook with only one usb-port. So I want to install the exact same version of OF on the suse 11.1 on that notebook. (and NOT boot from usb-device) I mounted the image and could not find the OF-source files. So how can I install the exact same version of OF from the stick on a my notebook ? thx & regards |
June 1, 2010, 08:19 |
Henrik Rusche
Rep Power: 18 |
Dear Heavy User,
the easiest solution to your problem is to install (k)ubuntu on your second laptop and add the openfoam packages and their dependencies https://launchpad.net/~cae-team/+archive/ppa?field.series_filter=lucid For OpenSuse, you need to compile from source, which can be checked out from sourceforge: Code:
svn co -r 1726 https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev Henrik |
June 1, 2010, 09:26 |
Hi Henrik,
thx again! I downloaded it. Is it 64-Bit or 32-Bit? So I assume i can just download the Thirdparty-package ( eg. here: http://sourceforge.net/projects/foam/files/ ) and /Allwmake it? Does the Thirdparty-package have to be 64-bit or 32-Bit ? regards! |
June 2, 2010, 04:27 |
Open Cascade
..not relevant..
June 2, 2010, 08:08 |
Hi There,
i tried to compile the OF-1.5-dev i downloaded from the link above.. It is not working... I messed around with the settings.sh but I just cant make it fly. Has anyone compiled this version from source yet? regards! Last edited by heavy_user; June 2, 2010 at 10:15. |
June 30, 2010, 03:30 |
Francesco Contino
I tried the USB stick distributed at the workshop (thank you very much, very good job) in a VirtualBox and everything was fine. Then I tried to redo the job with the tgz file from SourceFourge and it indicates "Boot error" when I try to launch it. Everything was done on the computer of one of my colleague and it works fine when he tried to directly boot on the stick. It would be fine too if I could directly boot on it but unfortunately, I am on a Mac. Is there any difference between the version distributed at the workshop and the one on SourceForge? Can anyone understand what's happening here? Thank you for your help. Francesco Contino |
July 7, 2010, 08:31 |
Dear all!
I tried to use your kubuntu *.iso to set up a desktop pc. The installation worked fine, but now I 'm facing troubles when trying to install other software. It complains about the permissions in the /tmp/ directory??? Thank you in advance for your help! Chris Last edited by cgoniva; July 8, 2010 at 08:38. |
July 8, 2010, 08:48 |
#11 |
Problem solved...
it was related to Salome's Install script. see: http://salome-platform.net/forum/forum_9/thread_2656 |
July 10, 2010, 19:34 |
installation of openfoam on kubuntu
#12 |
I downloaded openfoam_kubuntu.iso burned it to a DVD and installed it. It went pretty smooth but I cant find openfoam. Isnt it preinstalled? I can see and run all other programs like Paraview, Engrid, Octave etc. If someone can explain me how to make it work or install it I will be grateful. Thanks in advance. semo |
July 11, 2010, 13:14 |
#13 |
Håkan Nilsson
Rep Power: 18 |
Hi Semo,
If you learn to use the environment variables you don't need to know where it is installed. Try: echo $WM_PROJECT_DIR to see where it is installed. You should be able to run everything as it is. Everything should be set up for you. Håkan |
July 11, 2010, 14:09 |
starting openfoam
#14 |
Hello Hakan,
Thank you for your reply. You are right i don't need to know where it is installed. I just want to know how to see the interface of openfoam. I am sorry if this sounds stupid Thanks ... |
July 11, 2010, 16:36 |
#15 |
Håkan Nilsson
Rep Power: 18 |
Hi Semo,
It sounds like your question was not at all about the Kubuntu distro.... There is no graphical interface to OpenFOAM, which means that you have to learn something before using it. Please have a look at the user guide, which will give you the very basics. Good luck! Håkan |
July 13, 2010, 06:04 |
#16 |
Henrik Rusche
Rep Power: 18 |
Dear All,
the tgz and iso changed a few times. You can find the current SHA1 and MD5SUM in the "release notes" attached to the file. Henrik Last edited by henrik; July 13, 2010 at 07:14. |
July 22, 2010, 19:30 |
install OpenFOAM_Kubuntu 5th Workshop
#17 |
phong
Dear All
I downloaded OpenFOAM_kubuntu.iso and burn to DVD. (http://sourceforge.net/projects/open...u.iso/download) I installed OpenFOAM_kubuntu to my computer. I ran the cavity in my computer. when i ran icoFOAM i didn't see any folder ( 0.1, 0.2, 0.3, 0.4, 0.5 folder). I couldn't show any picture in paraview. But when i ran directly OpenFOAM_kubuntu on DVD, i could create 5 folder ( 0.1, 0.2, 0.3, 0.4, 0.5 folder) anh i could show any picture in cavity case. ------------------------------------------------ [IMG]file:///C:/DOCUME%7E1/THANHP%7E1/LOCALS%7E1/Temp/msohtml1/01/clip_image002.jpg[/IMG] I ran IcoFoam, it show: phong@phong-dell:~/OpenFOAM/phong-1.5-dev/run/tutorials/incompressible/icoFoam/cavity$ icoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5-dev | | \\ / A nd | Revision: exported | | \\/ M anipulation | Web: http://www.OpenFOAM.org | \*---------------------------------------------------------------------------*/ Exec : icoFoam Date : Jul 22 2010 Time : 15:15:33 Host : phong-dell PID : 2092 Case : /home/phong/OpenFOAM/phong-1.5-dev/run/tutorials/incompressible/icoFoam/cavity nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0 max: 0 velocity magnitude: 0 Attempt to return dictionary entry as a primitive file: /home/phong/OpenFOAM/phong-1.5-dev/run/tutorials/incompressible/icoFoam/cavity/system/fvSolution::U from line 30 to line 33. From function ITstream& primitiveEntry::stream() const in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 83. FOAM aborting Aborted ------------------------------------------ Please help me! Thankyou very much Phong |
July 26, 2010, 01:56 |
Please help me!
#18 |
phong
anybody hear my help? please help me!
I need to solve this problem and learn how to use it fluent. I loss too much the time to install linux and OpenFOAM. Now I install Kubuntu-OpenFOAM , i had new problem. I wait your good new. Thank you very much! Best regards. Phong |
July 26, 2010, 19:27 |
#19 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all,
I'm posting just to let you know that I've already answered Phong about the issue with KUbuntu + OpenFOAM-dev here: http://www.cfd-online.com/Forums/ope...tml#post268953 Best regards, Bruno PS: the Live KUbuntu + OpenFOAM-dev DVD looks very nice
July 29, 2010, 02:02 |
#20 |
phong
Thank you very much, Bruno
i had check it, i continue to study it. Best regards Phong |
OpenFOAM-dev Live USB CD, SLAX based | hellorishi | OpenFOAM Installation | 34 | May 31, 2010 01:18 |
OpenFOAM Live USB based on openSUSE 11.1 created with SUSE Studio | alberto | OpenFOAM | 40 | May 23, 2010 16:15 |
OpenFOAM 1.5 dev | LVDH | OpenFOAM | 98 | May 5, 2010 17:01 |
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev | titio | ParaView | 0 | December 9, 2009 12:12 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
