[Gmsh] Error when solving with simpleFoam fora file converted from Gmesh
Old   April 22, 2012, 09:56
Default Error when solving with simpleFoam fora file converted from Gmesh
guyb is on a distinguished road
Hello Everyone,
I had converted a .msh file using the gmshToFoam command and when i run the simpleFoam solver i get the following:
| \\ / O peration | Version: 2.1.0 |
| \\/ M anipulation | |
Build : 2.1.0-0bc225064152
Exec : simpleFoam
Date : Apr 22 2012
Time : 12:20:32
Host : "openFoam"
PID : 2132
Case : /opt/openfoam210/VelocityCaseLaminar
nProcs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::surfaceInterpolation::makeWeights() const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#4 Foam::surfaceInterpolation::weights() const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/simpleFoam"
#6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Floating point exception
I'm quite new to the OpenFoam and don't know how to solve this problem.
If anybody is familiar with this problem, please advise me on how to proceed.
Thanks
Guy
guyb is offline   Reply With Quote
Old   August 8, 2012, 05:34
Default Similar error
Maxime Thomas
Maxime Thomas is on a distinguished road
Hi Guy,
I have the same problem with my simulation. The mesh seems to be good, I defined all the boundary face and conditions, and when I launch simpleFoam I have the exact same message that appears.
Have you figured out your problem? I'm kind of desperate, I've already double checked all my geometry, direction of the faces and I'm out of any new idea to solve this problem.
If you found the solution could you please tell me how to proceed.
Thanks.
Maxime
eading field p
Reading field U
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::surfaceInterpolation::makeWeights() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4 Foam::surfaceInterpolation::weights() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/simpleFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Exception en point flottant
Maxime Thomas is offline   Reply With Quote
Old   August 16, 2012, 11:12
Hi Maxime,
I had managed to solve this problem. In my opinion (and please take into consideration i'm not an expert in OpenFoam...) there are two possible options, either you convert youe model/workspace to be axisymmetric and use the wedge option for your front and back patches, or you can make the width along the z axis (from front to back, direction) greater. I had used both in two different solutions, on the later option, for a model with a characteristic lenth of a 100 meters, i had changed the width from 1 meter to 10 meters and that had solved the problem.
Best of luck,
Guy
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 22:13
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
