[blockMesh] Sig11 on using 'tet' in blockMesh
Old   October 14, 2013, 05:58
Default Sig11 on using 'tet' in blockMesh
Ruud Vlaming
devlaam is on a distinguished road
Hi folks,
When trying a 'tet' in blockmesh I get a Sig11. Below is my file (slightly condensed), and underneath the console result. Is it forbidden to use 'tet' in
blockMesh? And if not, what am i doing wrong? It looks that everything goes well until the merge list.
FoamFile
{   version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict; }
convertToMeters 1;
vertices
(   (0 0 0)
    (1 0 0)
    (0 1 0)
    (0 0 1) );
blocks
( tet (0 1 2 3) (20 20 20) simpleGrading (1 1 1) );
boundary
(   xy
    { type patch;
      faces ( (0 2 1) ); }
    yz
    { type patch;
      faces ( (0 3 2) ); }
    zx
    { type patch;
      faces ( (0 1 3) ); }
    r
    { type patch;
      faces ( (1 2 3) ); } );
This is the console result:
|  \\    /   O peration     | Version:  2.2.x                                 |
Build  : 2.2.x-da11a20a3bfb
Exec   : blockMesh
Date   : Oct 14 2013
Time   : 11:43:13
Host   : "raaf"
PID    : 7621
Case   : [SNIP]/OpenFOAM/OpenFOAM-2.2.x/tutorials/electromagnetics/electrostaticFoam/test_01
nProcs : 1
Create time
Creating block mesh from
    "[SNIP]/OpenFOAM/OpenFOAM-2.2.x/tutorials/electromagnetics/electrostaticFoam/test_01/constant/polyMesh/blockMeshDict"
No non-linear edges defined
Creating topology blocks
Creating topology patches
Creating block mesh topology
Check topology
	Basic statistics
		Number of internal faces : 0
		Number of boundary faces : 4
		Number of defined boundary faces : 4
		Number of undefined boundary faces : 0
	Checking patch -> block consistency
Creating block offsets
Creating merge list Segmentation fault: 11
devlaam is offline   Reply With Quote
Old   October 17, 2013, 15:50
Retired Super Moderator
Bruno Santos
Greetings devlaam and welcome to the forum!AFAIK, in the official OpenFOAM version, blockMesh can only handle "hex" blocks.
For getting tet-like blocks, you need to collapse edges, as explained near the end of this page: http://www.openfoam.org/docs/user/blockMesh.php
Best regards,
Bruno
Old   October 17, 2013, 16:29
Ruud Vlaming
Thank you wyldckat, for taking the time to answer my question.
Yes, i found that out in the mean time. I was put in the wrong direction because blockMesh does not reject the input but starts processing. I assumed, like happens when you put invalid keywords in dictionaries in general it would report that, and not generate a segmentation fault. Pretty drastic response to my taste!
blockmesh, sig11, tet, tetrahedron
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 01:18
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
