[snappyHexMesh] SnappyHexMesh warning: "Displacement ... points through the surrounding patch faces."
Like Tree1Likes
  • 1 Post By wyldckat
Old   December 23, 2014, 09:16
Default SnappyHexMesh warning: "Displacement ... points through the surrounding patch faces."
Chunsheng Wang
Chunsheng is on a distinguished road
Hi there,
When I ran SnappyHexMesh, I had the following message:
Displacement (5.8142979e-10 2.7231409e-10 1.3694218e-09) at mesh point 483739 coord (-0.044907379 -0.015238973 -0.070068371) points through the surrounding patch faces.
What does it mean?
Chunsheng is offline   Reply With Quote
Old   December 26, 2014, 23:50
Chunsheng Wang
Problem solved
Old   December 27, 2014, 05:17
Retired Super Moderator
Bruno Santos
Greetings Chunsheng and welcome to posting on the forum!
We're glad that you've managed to solve your problem, but it would nice if you could share what the solution was
Best regards,
Bruno
Ngaru likes this.
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
[snappyHexMesh] SnappyHexMesh Displacement at mesh point...points through the surrounding patch faces pizzaspinate OpenFOAM Meshing & Mesh Conversion 16 March 9, 2015 13:52
