[Other] Dynamic Mesh with Rotating Wheels touching the Ground
Like Tree2Likes
  • 2 Post By tomf
Old   June 22, 2015, 09:56
Default Dynamic Mesh with Rotating Wheels touching the Ground
Christopher
Chrissi is on a distinguished road
Hello everybody,
for my bachelorthesis I was given the task to develop a meshing process in order to do simulations with rotating bodies (DynamicMesh) in OpenFOAM.
As a testcase we have taken a car with rotating wheels because my company is very interested in car simulations. In order to simplify the testcase we let a small gap between the wheel and the moving ground.
(thatīs not what happens in reality, but the first aim was just to develop the process and show that calculations with OpenFOAM can be done).
Meshes were created separately (similar like itīs described in another thread).
Everything went fine and we can do DynamicMesh simulations now.
But now weīre thinking about to do the next step and want to realize more realistic simulations. The main problem to face with Dynamic Mesh in car simulations is the contact between the wheel and the ground because normally the wheels are cut in aerodynamic simulations in order to consider the wheel deformation.
At the moment it seems quite difficult to me to get an idea how something like that could be realized with rotating meshes.
Another idea to do DyM simulations with the tire touching the ground would be a simulation in which you just rotate the rims and do an mrf calculation or another steady-state approach for the car tire. Has anybody already gained experience with that? Or has anybody advice how that could be realized in OpenFOAM.
I hope I could explain you my problem. Feel free to ask further questions.
Greetings
Chrissi
Chrissi is offline   Reply With Quote
Old   June 25, 2015, 11:52
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Chrissi,
I would go for the second approach and use the tire with the rotatingWallVelocity boundary condition. You can use this boundary condition if the tire has all it's faces tangential to the rotation. You would than indeed have the rim in a cellzone that is moved using a dynamic mesh approach, but your tire is in the stationary mesh, but does have velocity (like a spinning disc).
Regards,
Tom
tomf is offline   Reply With Quote
Old   June 26, 2015, 05:31
Christopher
Hi Tom,
that was also my first intention. But it seems a little bit difficult to me how to define the AMI Interface between the Tire and the Rim because there is no mesh between these bodies. And normally i need two meshes (one on each side of the AMI) to define this Interface.
I already read about the ACMI but the appropriate tutorial case doesnīt really catch my problem
Do you have any idea how to deal with this problem? Or is there a special strategy for this?
Greetings
Chrissi
Old   June 26, 2015, 05:35
Tom Fahner
Well I think you can define an interface that has the entire rim encapsulated and ends somewhere on the tire. This is your AMI, it is only an interface between volume cells on the different sides of the interface, there is no connection between vertices on both sides of the interface. I might be able to give you an example, but at the moment this takes a bit too much time.
Old   June 29, 2015, 06:58
Christopher
Hello Tom,
that would be very nice if you gave me a short example. So you would define a cylinder which ends on the tire and surrounds my whole rim? But how can i mesh that? Because my cylinder then is cutting my tire?!
In addition to that I will need two separate parts (rim+tire) or at least two separate regions in my STL file, or am I wrong?
Thanks for your help
Chrissi
Old   July 5, 2015, 05:58
Tom Fahner
Finally managed to get an example for you. Most of the time I will not use snappy, so I am not quite sure how everything works for that, but I would suggest looking at one of the AMI tutorials that use snappy (propeller example in pimpleDyMFoam maybe?).
The final case would look something like you can find here (please note that the link will be valid for about 1-2 weeks):
Example case.
This is a case that should have all the ingredients schematically for what you want to do: A wheel, with rims, and an AMI interface that allows the wheels to rotate, but have the tire stagnant that touches the road, but with a rotatingWall boundary condition in order to include the rotation.
Note that it is just an example case (Domain is not split in inlet and outlet, mesh is way too coarse and has no boundary layer mesh etc.) I checked that it ran for a couple of time steps, but it may fail at some moment. For an actual case I would probably have made a fillet or something similar between the road and the tire to mimic a contact patch and loose the sharp edge between them.
So, this case should give you an idea, but you should need to find a way to do this with snappy.
Good luck,
Tom
Old   July 12, 2015, 04:02
Default propller domain meshing
sohrabmajd is on a distinguished road
hi 2 all
I'm new user of ansys that want to use ansys cfx for a ducted propeller.
i can't mesh my model as good as that my solver give me best results.
how can i mesh my model with boundary layers that have fine meshes near propeller and duct and meshes grow slowly linearly with distance from the duct?
I work with ansys workbench and fluid flow(CFX).
thanks
sohrabmajd is offline   Reply With Quote
Old   July 13, 2015, 06:05
Christopher
Hello Tom,
could it be that you have forgotten to attach the blockMeshDict respecitvely the createPatchDict? I canīt find them in the file you have uploaded.
Thanks for your help.
Old   July 13, 2015, 06:23
Tom Fahner
Hi Chrissi,
Like I said, I did not use blockMesh/snappyHexMesh to make the mesh, I used a commercial mesher (hence the tetrahedral meshes). It was just meant to give an example. Therefore I do not need to modify it. Please examine the way it was set-up, including the boundary conditions for the wheel/rim/spokes etc.
I think you could recreate this in snappy, just make sure you have the AMI patches as refinement surfaces, STL would probably be best and snap to them from both sides. However I am not really an expert on snappy.
Good luck,
Tom
Old   December 10, 2015, 10:37
LU
louvel is on a distinguished road
Originally Posted by tomf View Post
Example case.
Good luck,
Tom
Hello Dear Tom
And now also need to do the rotating wheels with dynamic mesh . I find your messages here is really very good and helpful .could you also send me the example case, it would be really nice that i could lernen a lot from that.)
Thank you so much
louvel is offline   Reply With Quote
Old   January 5, 2016, 10:37
Tom Fahner
Hi Louvel,
You just caught me during a rather long holiday, so unfortunately I could only respond today. I have created a dropbox so I do not have to use links that expire.
For anyone else reading this thread, the example can be found in my Dropbox.
louvel and FDelic like this.
Old   January 11, 2016, 06:38
LU
thank you so much! got it!
and happy new year!
best regard!
Reconstruction of the parallel case with dynamic mesh makaveli_lcf OpenFOAM Post-Processing 7 October 18, 2023 11:28
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 11:39
Multiple rotating frame VS dynamic mesh Jen FLUENT 3 July 2, 2005 06:31
