[Other] Problems following the user guide(mapFields ... -consistent). |
October 12, 2017, 19:49 |
#1 | ||
Oscar Amarilla
Hi everyone!
I'm new using openFoam, so I'm trying to follow the examples of the chapter 2. At the section 2.1.5.3 I have to run mapFields ../cavity -consistent and the terminal have to show Quote:
Thanks for advance. |
October 19, 2017, 13:11 |
#2 | |
Rep Power: 12 |
I never used mapfields but it seems to me that mapFields has done it's job as it should because it finished without error even though the AMI wasn't created Mapfields should run without a mapFieldsDict if used with the parameter -consistent. If you followed the tutorial most of the things you need should be provided. Just try to proceed with the guides steps.
A "." in linux means the folder you are in. A ".." in linux means a the folder before the folder. So one up in the foldertree. Quote:
Target is the case you want to set your field information alike the source. Last edited by Heremus; October 19, 2017 at 13:26. Reason: no paragraphs? script problems. |
Adding a user application class | Rasmus Gjesing (Gjesing) | OpenFOAM Pre-Processing | 57 | February 3, 2010 03:45 |
user routine, user funcion, or fortran compile effect on the memroy? | princeps11 | CFX | 1 | May 13, 2009 18:37 |
Problems with User Defined Scalar | Alberto Cuoci | FLUENT | 0 | June 26, 2007 14:55 |
Installation problems Canbt open OpenFOAM13bashrc | dim | OpenFOAM Installation | 8 | March 9, 2007 17:27 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
