[mesh manipulation] Skewed cells after mergeOrSplitBaffles |
September 9, 2019, 11:51 |
anonymous
Hello together
I have a problem with skewed cells. If I check the grid after snappyHexMesh everything is fine. However, if I use the createBaffles and mergeOrSplitBaffles -split commands, I get skew cells around the AMI zone (As in tutorial https://github.com/OpenFOAM/OpenFOAM...mixerVesselAMI). I have already tried different refinements of the grid, but without success. Can someone help me with this problem? Thank you so much for your support. Biotech |
ami patches, skewed cells, snappyhexmesh |
[snappyHexMesh] sHM - flat-/ double lined cells | pconen | OpenFOAM Meshing & Mesh Conversion | 1 | February 1, 2023 04:40 |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 11:28 |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[snappyHexMesh] snappyHexMesh Segmentation Fault | avd28 | OpenFOAM Meshing & Mesh Conversion | 11 | May 11, 2015 20:32 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
