[snappyHexMesh] Smooth Devision around objects with sHM |
December 29, 2023, 13:00 |
#21 |
Saeed Jamshidi
Rep Power: 7 |
Hello again 👋
I have come across another interesting question in regarding SnappyHexMesh. Is it possible to get the number of devisions around an object, for instance a cylinder? Let's consider refinement level (6,6). I know the the theory of the refinement and I have attached a figure for that, nevertheless, what about the number of element around the cylinder? Thank you for your advice. |
December 29, 2023, 13:22 |
#22 |
Yann
Rep Power: 26 |
Hello Saeed,
In snappyHexMeshDict you can activate some writeFlags to write the refinement level as a scalar field. (check the end of snappyHexMeshDict here: https://develop.openfoam.com/Develop...ppyHexMeshDict) Then you can use the treshold filter in ParaView to filter cells based on their refinement level. In the information tab you should get the cell count. Let me know if this answers your question! Regards, Yann |
December 29, 2023, 13:32 |
#23 |
Saeed Jamshidi
Rep Power: 7 |
Thank you Yann🙏
As always helpful. |
Run function objects on final time | b.simpson | OpenFOAM Post-Processing | 3 | September 19, 2022 20:09 |
[snappyHexMesh] Advice on limitations of SHM | Tobermory | OpenFOAM Meshing & Mesh Conversion | 0 | February 26, 2021 07:09 |
Multiple floating objects using InterDyMFoam and sixDoFRigidBodyMotion solver | FloatingSolar | OpenFOAM Running, Solving & CFD | 4 | December 29, 2020 11:09 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 01:56 |
Using clip filter to acquire smooth interface | sharonyue | OpenFOAM Post-Processing | 0 | April 14, 2015 11:03 |
