[mesh manipulation] try to do axisymmetric flow with makeAxialMesh but failed |
January 28, 2024, 22:28 |
Rep Power: 3 |
I was doing some kind of nozzle flow (may check the youtube reference Merlin nozzle). I did the mesh at Ansys Fluent and imported into OpenFOAM v1912. I would like to do axisymmetric analysis (encouraged by all) so I tried to use makeAxialMesh utility but this utility seemed not compatible w the version. so I've downloaded OpenFOAM 2.0.0 which should be compatible w this utility, ended out w errors (command not found) again. Anyone has hint on this? Please advise me. should I download older version like 1.4.1? or I can go with 5.0 version too? I saw people sharing the tar.gz file of makeAxialMesh utility. And there is few taught me to use extrude2DMesh (they said worked just like makeAxialMesh). |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
3D axisymmetric flow in cylindrical coordinate = 2D cartesian flow? | shubiaohewan | Main CFD Forum | 10 | May 2, 2013 14:08 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
Convergence for axisymmetric flow | bl201 | Main CFD Forum | 5 | August 16, 2005 17:01 |
