[snappyHexMesh] BC patchs on mesh with snappyhexmesh
Old   September 16, 2010, 12:04
Default BC patchs on mesh with snappyhexmesh
Nilesh Rane
nileshjrane is on a distinguished road
I am trying to mesh a pipe joint. Blockmesh gives bad cells which are blowing my solution. I was thinking of snappyHexMesh. But i am not sure whether one can apply BC patches to the surface that you mesh using snappyHexMesh. To be more specific, i would be importing pipe surface stl file and mesh it internally using sHM. but can i assign inlet outlet wall etc BC patches on the pipe surface??? How to do that if at all its possible.??
Thank you..
Nilesh
Imagination is more important than knowledge..
nileshjrane is offline   Reply With Quote
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 11:50
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 19:54
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
