[Commercial meshers] Check Mesh error ... Please help me
Old   February 9, 2011, 08:07
Unhappy Check Mesh error ... Please help me
boyington is on a distinguished road
Hi.
I've a big issue that I can't understand.
After the fluent3DMeshToFoam command, i would like to know if my mesh was good enough so .... checkMesh.... and that's what i received from the command windows :
| \\ / O peration | Version: 1.7.x |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.x-4bbf33160caf
Exec : checkMesh
Date : Feb 09 2011
Time : 14:02:20
PID : 4947
Case : /home/Ares
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create polyMesh for time = 0
--> FOAM Warning :
From function polyMesh(const IOobject&)
in file meshes/polyMesh/polyMesh.C at line 307
no cells in mesh
Time = 0
Mesh stats
internal points: 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam:rimitiveMesh::calcCells(Foam::List<Foam::ce ll>&, Foam::UList<int> const&, Foam::UList<int> const&, int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam:rimitiveMesh::calcCells() const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam:rimitiveMesh::cells() const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
in "/opt/openfoam171/applications/bin/linuxGccDPOpt/checkMesh"
#8 __libc_start_main in "/lib/libc.so.6"
Erreur de segmentation
If someone could help me to understand this error.
thanks a lot
boyington is offline   Reply With Quote
Old   February 9, 2011, 08:22
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
If I was you, I would focus on this line...
no cells in mesh
niklas is offline   Reply With Quote
Old   February 9, 2011, 10:33
It's strange .... because when I put fluent3DtoFoam, it tells me that I've over 13000 cells in my mesh ... so ...maybe i've to change another file before running check mesh ? what do you think ?
Old   February 11, 2011, 01:31
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you try fluentMeshToFoam instead of fluent3DMeshToFoam?
I use fluent3DMeshToFoam if I have hanging nodes in my mesh (tetra-hexcore mesh). Else I use fluentMeshToFoam
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[ICEM] Nuclear fuel assembly, Mesh Check: "missing internal faces, uncovered faces" swparth ANSYS Meshing & Geometry 2 June 27, 2017 07:12
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
