Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation
Like Tree9Likes
Old   August 11, 2011, 20:01
Default Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation
Scott Rumage
scott_rumage is on a distinguished road
Tecplot, Inc. is developing an OpenFOAM© data loader for the next release of Tecplot 360, and has made a beta version available for evaluation and testing at: http://download.tecplot.com/360/beta/ .
Please note that you will need a Tecplot 360 2011 license key to run the beta version. If you already have a 2011 key, simply copy the license file into the install directory, or point to the network license manager, to the activate the software.
If you do not have a 360 2011 key, send e-mail to marketing@tecplot.com with “OpenFOAM loader evaluation” in the subject line and your contact information in the body, and we will send you an evaluation key
As an FYI, the beta will install in a new directory so you can run both the released version of Tecplot 360 2011 R1 and R2 beta on your machine without any conflicts.
Thanks for giving the OpenFOAM loader a test-run. We look forward to your feedback on the new loader.
scott_rumage is offline   Reply With Quote
Old   August 24, 2011, 04:19
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
hello sir
plz give me the information about uploading the .plt file of openfoam in to tecplot
example like i run cavity tutorial of openfoam then after completing paraview process i close the peraview then after i run the command foamToTecplot360
then it gave me some files which converted in to .plt format
now i install tecplot in windows 7 n when i run this .plt file in tecplot then it gave me some error like
the grid file must be specified before any solution file that depend on it.
so how can i plot my result in tecplot?
plz help me
jignesh_thaker2007 is offline   Reply With Quote
Old   August 24, 2011, 11:41
Scott Rumage
Hello Jignesh,
This thread is in regards to our new Tecplot 360 data loader for OpenFOAM data loader, and I will attempt to explain the difference.
The data loader reads the OpenFOAM results in the native output from OpenFOAM, so the conversion step (foamToTecplot360) is not necessary. This data loader runs inside the Tecplot 360 software program.
The data converter (foamToTecplot360) is a separate application that is run outside of Tecplot 360, and it creates the native Tecplot format which has the .plt extension.
One would read a native .plt file into Tecplot via File>>Load Data Files>>Tecplot Data Loader. One would read the native OpenFOAM files via File>>Load Data Files>>OpenFOAM Loader.
I believe your specific problem may be the order in that you are trying to load your OpenFOAM results in .plt form. One first must load the grid file, and then follow with the solution files.
I hope this helps.
Regards,
Scott
vivek05 likes this.
Old   August 24, 2011, 13:39
Default hello sir
Jignesh
thanks for ur kind reply
its work
thanx again sir
Old   September 26, 2011, 07:39
Dennis Kingsley
dkingsley is on a distinguished road
Scott,
Nice job, I finally got the chance to work with the native OF loader this weekend and it is amazing how much time can be re-cooped when you don't need to deal with translators and intermediate files.
Dennis
dkingsley is offline   Reply With Quote
Old   September 27, 2011, 12:01
Ashish Nedungadi
ashishnedungadi is on a distinguished road
Excellent job with the native Tecplot OpenFOAM reader. I downloaded the beta, installed, and was up and running in less than 5 minutes. I tested a serial, unsteady case and that worked great. I also tried a decomposed (parallel) case, where the OpenFOAM data was still in its decomposed state, and that worked great too.
This process definitely saves time and disk space.
ashishnedungadi is offline   Reply With Quote
Old   October 11, 2011, 14:27
Senthil Kabilan
skabilan is on a distinguished road
Hi Scott,
Nice job integrating the native OpenFOAM reader into Tecplot! I was able to view the results from a decomposed OpenFOAM case with just a click of a button. Saves a lot of time and disk space. If not for the OpenFOAM reader in Tecplot, I should have reconstructed the processor files, then use foamToTecplot360 to convert the results into .plt files and then use Tecplot.
Its quick now. Cant ask for more! Keep up the good work!
Cheers
Senthil
skabilan is offline   Reply With Quote
Old   October 11, 2011, 16:42
Pablo Higuera
Phicau is on a distinguished road
Hey skabilian
there's no need to reconstruct a case in order to view it: just type "paraFoam -touch", then rename the file created as *.FOAM and use paraview to open it normally (regular paraview, not through paraFoam script), you should choose OpenFOAM reader (lying in the middle of all). You can now choose between viewing the decomposed or the reconstructed case.
I still have to check out this one, but paraview is pretty decent for most of the things.
Regards
H
Tushar@cfd and y_jiang like this.
Phicau is offline   Reply With Quote
Old   October 11, 2011, 16:54
Senthil Kabilan
Hi Pablo,
Thanks for the information on paraview. I have been using Tecplot for the past decade, so i am very used to it. Before this Beta release, Tecplot did not have the capability to read files without reconstructing and using foamToTecplot360 utility. With the new Beta release, we don not have to do that. So, I am excited. I am definitely not comparing Tecplot to Paraview! I am just telling that the new capability is cool.
Regards,
Senthil
Old   November 1, 2011, 17:35
Scott Rumage
Tecplot 360 2011 with the OpenFOAM © data loader is now officially released.
One can upgrade their current license of Tecplot 360 to this new version at this link: http://www.tecplot.com/Downloads/SoftwareUpgrade.aspx
One can obtain a 14 day evaluation of this new version of Tecplot 360 at this link: http://www.tecplot.com/Downloads/EvaluationSoftware/Tecplot360.aspx
You are welcome to contact me if you have questions or suggestions regarding this new capability.
Regards,
Scott
Old   November 22, 2011, 19:41
Scott Rumage
Hi All,
Just a note to let you know that we are aware that the new Tecplot 360 OpenFOAM data loader does not handle multi-region data sets nicely. We will be fixing this issue, and I will post a link to the update when it is available.
As an fyi though – multi-processor OF data is supported by the new Tecplot 360 data loader.
Cheers,
Scott
Old   November 25, 2011, 08:57
Dr. Fabian Schlegel
fs82 is on a distinguished road
I was very happy to read that Tecplot 360 now offers a native Openfoam loader. I tried it and the first thought I had in mind was: it is pretty slow. My testcase has about 200000 grid points and many time directories. Due to the fact that the foam loader loads all time directories (there is not option to specifiy just one) it slows down rapidly. You should add a option to load just one time directory. Normally one needs only the last one, but some checkpoints during the run, to allow e.g. for a restart in case of error or on high performance computers. And a problem which also exists for the converter foamToTecplot360: The output for probes during runtime could not be loaded into tecplot.
But again, it very nice to have a native foam loader. It simplifies the working alot.
kind regards,
Fabian
fs82 is offline   Reply With Quote
Old   November 28, 2011, 10:33
Scott Rumage
Fabian,
Thank you for the good suggestion on the option on a method to load time dependent solutions. I will pass it on to our developers.
Regards,
Scott
Old   April 11, 2012, 04:22
akidess's Avatar
Anton Kidess
It would be great if the Tecplot reader could handle geometry data in binary format (I get a SYS_ERROR_FORMAT message). After using foamFormatConvert to write the geometry data in constant/polyMesh in ascii format, the Tecplot reader works as expected. foamToTecplot360 works without any issues on the binary files.
vivek05 likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   April 11, 2012, 13:12
Scott Rumage
Anton,
I have noted the issue, and we will work including this capability in a future version of Tecplot 360's OpenFOAM data loader.
Thanks for the suggestion,
Scott
Old   April 29, 2012, 14:30
Default Velocity at Wall not zero
  #16
Sebastian
Johan_87 is on a distinguished road
Hey all,
I got a question about postprocessing my data from OpenFOAM in Tecplot.
For example if I load the data of the cavity case in Tecplot I observe wall velocities to be non-zero which have to be zero.
My question is if this is a general problem of OpenFoam because it uses
co-located meshes and saves all cell data in one point in the center of the cell,
or if this is a problem of Tecplot getting any data wrong?
Is there any way to get the velocity at the wall to zero in tecplot?
Thanks, Sebastian
vivek05 likes this.
Johan_87 is offline   Reply With Quote
Old   June 19, 2013, 15:26
Default Tecplot 360 2012R1 OF Native Loader
  #17
anfho is on a distinguished road
Hi All,
I am using OF 2.1.1 and Tecplot 360 2012R1.
I am somewhat confused on how to use the Tecplot native loader.
I ran the damBreakFine tutorial (http://www.openfoam.org/docs/user/da...x7-610002.3.11) and trying to load the results.
The loader looks for a controlDict but does not read it correctly when I am trying to load it:
PHP Code:
The FEA Loader encountered an internal error from reading the file which may affect loading.
Funktionvdm_OpenFoamLibOpen
Error
SYS_ERROR_FORMAT Improper or incomplete file format
Message
Invalid points file
Attempting to
continue...
I have tried several different files (grid files or solution files) but they would not load
How do I correctly load OF results with the Tecplot native loader?
Is there something wrong with my OF openMPI installation (reconstructPar; did not get any error messages when executing reconstructPar) and does that produce corrupted files?
Thanks!
Andreas
anfho is offline   Reply With Quote
Old   June 24, 2013, 02:37
Dr. Fabian Schlegel
You have to run blockMesh (in your case directory just type blockMesh and hit Enter) first. Tecplot is complaining about a missing point file, which means there exists no mesh description.
Best regards,
Fabian
Old   August 21, 2013, 03:23
CFDnewbie147 is on a distinguished road
I've the same problem as anfho descriped. But even if I do the Allrun sript and so the blockMesh again and try to load the controlDict with the tecplot360 reader, I get allways the error message posted by anfho.
I hope you can help me.
Best regards, CFDNewbie147
CFDnewbie147 is offline   Reply With Quote
Old   August 21, 2013, 13:32
Retired Super Moderator
Bruno Santos
Hi CFDNewbie147,
Which version of Tecplot are you using?
As for the missing "points" file, run the following command on the terminal:
checkMesh -constant
Best regards,
Bruno
y_jiang likes this.
Reading Additional Data Quantities from Fluent into Tecplot fremder Tecplot 9 December 16, 2016 15:35
CFX-Post and Tecplot 360 Rogerio Fernandes Brito CFX 2 September 28, 2008 14:45
extracting data in tecplot peter FLUENT 0 September 24, 2008 11:11
tecplot 360 vs. 10 compatibility N.R. Tecplot 6 December 12, 2007 13:23
Exporting data to Tecplot 360 Genesis FLUENT 2 June 6, 2007 17:53
