Set a face as the inlet
Old   March 25, 2022, 06:47
Default Set a face as the inlet
Haroun
Haroun is on a distinguished road
Hi everyone,
So I am new to OpenFOAM and I have this simple system composed of two injectors (water and air) and a mixing room. I have in total 6 .stl files which are described by their names :
'INLET_AIR'
'INLET_WATER'
'WALL_AIR'
'WALL_WATER'
'OUTLET'
'PLENUM'
I've just done the meshing part and everything seems to be OK. Now, I only want to set the surface of 'INLET_WATER' as the inlet surface but I absolutely have no idea of how to proceed since in every tutorial I did they define the inlet and outlet as faces of the bloc generated from blockMesh.
What is the procedure to set a face of the geometry as the inlet and not a face of the bloc ?
Haroun is offline   Reply With Quote
[surface handling] Decomposing Faces after Extrude2DMesh with autoPatch JEBland OpenFOAM Meshing & Mesh Conversion 5 December 6, 2021 07:28
Seakeeping Solver:Crashed akbarbagusd Fidelity CFD 0 November 5, 2021 12:42
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
