February 27, 2014, 16:29 |
Running a code in multi-core processor
Parisa
Rep Power: 13 |
Hi everyone,
I am using OpenFOAM 2.1.1. I am wondering if I can run the cases in multi cores? My machine has 2 CPUs, each include 12 cores. I really appreciate your support, Parisa |
February 27, 2014, 17:10 |
Lieven
Rep Power: 22 |
Hi Parisa,
Briefly said, you need to decompose your case using the 'decomposePar' utility and start the job with e.g. (adjust the solver name to your own preference) Code:
foamJob -p simpleFoam http://www.openfoam.org/docs/user/da...hp#x7-500002.3 Cheers, Lieven |
February 27, 2014, 18:12 |
Parisa
Rep Power: 13 |
Thanks for your help,
In the tutorial, it is decomposed for several CPUs. But I would lke to run in different cores. Is there any difference? |
February 28, 2014, 04:07 |
Lieven
Rep Power: 22 |
There is no difference, since you select the number of processors. Using your terminlogoly:
you have 24 processors in total (2x12). You can select any number of processors between 1 and 23 to do the calculations. OpenFOAM will divide the work over the difference CPUs and cores automatically. But always test if your simulation effectively runs faster when increasing the number of cores. So don't blindly jump to 23 processors, test with 4, 8, 16 or so and check if the computation time decreases with increasing number of procs. Just as a note, you shouldn't select all 24 processors since you need one for the operating system. Cheers, L |
May 6, 2014, 22:10 |
Niu
Rep Power: 12 |
Hi Lieven,
Do you know how to run reconstructPar in parallel? |
May 7, 2014, 04:30 |
Lieven
Rep Power: 22 |
Hi Z.Q. Niu,
As far as I know this is not possible... |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
decomposePar 4-core warning/error? | Boloar | OpenFOAM Bugs | 23 | April 8, 2014 08:57 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
