Problem writing to dictionary
Old   April 14, 2016, 10:17
Question Problem writing to dictionary
Rasmus Andersson
MrAndersson is on a distinguished road
Hello!
I am developing an OpenFOAM model for electrolytes and in this context one module predicts diffusivities and is supposed to write its results to a dictionary for others to read. Writing to dictionaries seems straight-forward enough, but for some reason I can't get it to work. This is how I define the IODictionary to be written to:
IOdictionary electrolyteProperties
    IOobject
        "electrolyteProperties",
        runTime.constant(),
        mesh,
        IOobject::MUST_READ_IF_MODIFIED,
        IOobject::NO_WRITE
I then define a subdictionary "DDict" inside "electrolyteDict":
dictionary& DDict = electrolyteProperties.subDict("D");
DDict contains dimensions and values of diffusivities for different species and may look something like this:
D
    dimensions    [ 0  2 -1  0  0  0  0];
    values
            1e-12
            1e-12
            1e-12
I try to write the entry by using set:
 electrolyteProperties.set("values",DVals);
A printout of DVals gives:
DVals: 3(4.34118e-12 4.56812e-12 3.49564e-12)
which is what I want to write to the dictionary. The whole thing compiles without warning and runs without problems, the values just never get changed to the calculated ones. I have also tried to write directly to the parent dictionary (electrolyteProperties) to see whether the problem has to do with the usage of subDict, but that doesn't work either.
Anyone have an idea of what may cause my problem?
MrAndersson is offline   Reply With Quote
Old   April 14, 2016, 10:54
Rasmus Andersson
Actually, printing the dictionary (using Info) gives exactly what I want, but it never ends up in the file. Do I need to call some write function of some sort? Just writing DDict.write() or electrolyteProperties.write() does not work, then the compiler complains that function call is ambiguous.
Old   April 14, 2016, 15:57
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You can resolve write method ambiguity, for example, like this:
      IOobject
          runTime.constant(),
          mesh,
          IOobject::NO_WRITE
  scalarList DVals;
  ... fill DVals ...
  DDict.set("values", DVals);
  electrolyteProperties.regIOobject::write();
alexeym is offline   Reply With Quote
Old   April 15, 2016, 06:00
Rasmus Andersson
Thanks a lot Alexey! That solved my problem.
/Rasmus
Old   September 12, 2017, 15:46
Default declaration issues with update code
Klaus
klausb will become famous soon enough
I run into compile errors with this code which I want to use to update some values in a dictionary:
code:
// IO test changing p-minIter value in fvSolutions file
// Declare dictionary
IOdictionary fvSolution(IOobject("fvSolution",runTime.system(),mesh,IOobject::NO_READ,IOobject::AUTO_WRITE));
// Declare subdictionary
dictionary mySubDictUpdate(fvSolution.subDict("p"));
// Update some values
mySubDictUpdate.set("minIter", 33 );
mySubDictUpdate.set("maxIter", 500 );
errors:
myPCG_solve.C:111:1: error: ‘IOdictionary’ was not declared in this scope
IOdictionary fvSolution(IOobject("fvSolution",runTime.system(), mesh,IOobject::NO_READ,IOobject::AUTO_WRITE));
myPCG_solve.C:114:1: error: ‘dictionary’ was not declared in this scope
myPCG_solve.C:117:1: error: ‘mySubDictUpdate’ was not declared in this scope
myPCG_solve.C:122:1: error: ‘fvSolution’ was not declared in this scope
fvSolution.Foam::IOobject::write();
myPCG_solve.C:122:18: error: ‘Foam::IOobject’ has not been declared
How can I declare the object and dictionaries "in this scope"?
Klaus
klausb is offline   Reply With Quote
dictionaries, write data, write to file
How to Mix AIR and WATER Elvis1991 FLUENT 12 December 1, 2016 12:28
Writing udf for Transient Heat conduction boundary value problem abhi12019 FLUENT 3 October 7, 2015 09:10
writing subDict in a dictionary ubaid OpenFOAM Programming & Development 3 October 25, 2014 17:17
[Other] Problem with the dictionary file sfigato OpenFOAM Meshing & Mesh Conversion 5 January 17, 2013 08:55
Problem while writing pressure file "buoyantPressure" ubaid OpenFOAM 0 October 2, 2010 14:07
