June 17, 2016, 06:52 |
OpenFoam Compiler
toboto
Rep Power: 9 |
Dear All,
I've just started my journey with OpenFOAM 3 months ago. I've used the standard solvers to run some cases with some success. Now I am trying to learn how to develop new solvers or modify old ones. I've background about C++ but I think it isn't enough to proceed with OF development. So, I decided to follow an OpenFoam development dedicated course. I found course by Chalmers "OpenSource CFD for industry – high-level development" is a good start (with other courses available online). My problem now is that while learning I need to apply the small examples given in the course. e.g: info << T.xy() << endl; For general C++ I was using any compile or IDE to do that but obviously this will not work because "info" isn't a standard C++ object. I tried to include the corresponding .h files and include foam namespace in my code but this lead me to errors asking for another .h files. Is there any way to overcome this problem? Best regards. |
June 17, 2016, 12:13 |
David Gaden
Rep Power: 22 |
I think it would be best if you work within a working OpenFOAM environment. You can create your own folder outside of the OpenFOAM source code... but the Make/files and Make/options needs to reference OpenFOAM-related stuff. You might create your own lib and bin output folders (i.e. where you tell it to put the compiled output at the bottom of Make/files).
I personally just use a text editor, and then OpenFOAM's built-in wmake for compiling. I've heard some people have success using Eclipse for development.
~~~ Follow me on twitter @DavidGaden |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
Error compiling OpenFoam 1.6.x with intel compiler icc | mak_04 | OpenFOAM Installation | 5 | October 28, 2011 07:06 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
