September 9, 2018, 01:54 |
How is pEqn().flux() calculated?
krishna kant
Rep Power: 10 |
For my better understanding of the PISO I want to understand how pEqn().flux() used for updating phi is calculated. I searched in many threads but didn't find something yet. Can anyone suggest a thread or explain the calculation.
Thanks in advance. |
September 16, 2018, 07:29 |
Michael Alletto
Rep Power: 15 |
You can find a description in
Description of flux() method The basic idea behind the use of the pEqn.flux() function in the framework of the simple algorithm is to have a flux field consistent with the derivation of the pressure equation: For the derivation of the pressure equation one assumes that the sum of the phase velocity fluxes vanishes (divergence free flow). Once the pressure equation is solved, the phase fluxes are updated once to be consistent with the derivation of the pressure equation. |
wallHeatFlux utility for an incompressible case | Mr.Jingles | OpenFOAM Post-Processing | 67 | April 6, 2023 03:25 |
dsmcFoam setup | hherbol | OpenFOAM Pre-Processing | 1 | November 19, 2021 01:52 |
buoyantBoussineqPimpleFoam Gravity Current | Bish | OpenFOAM | 0 | February 1, 2018 09:36 |
phi == pEqn.flux() rhoSimpleFoam | David1 | OpenFOAM Programming & Development | 0 | July 9, 2015 10:10 |
pEqn.flux() | cheng1988sjtu | OpenFOAM Running, Solving & CFD | 4 | November 21, 2012 15:08 |
