May 7, 2020, 13:40 |
OpenFOAM coupling with matlab
sreekanth
Rep Power: 6 |
I am working on a Sloshing tank 2d simulation problem. Initially, I have used linear motion for simulation and successfully simulated the programme. The next task I am assigned is with two-way coupling with Matlab. I followed a reference work: http://www.tfd.chalmers.se/~hani/kur...D3D_Report.pdf Using this file I have created a matlabPipe.so file which calls Matlab engine.h The basic idea is to extract sloshing force from OpenFOAM at each time step and give these input values to Matlab and the Matlab calculates the displacement using numerical integration and returns back the value to Open foam in terms of displacement (amplitude) values. The description is also given in the flowchart. I understood that the Matlab engine works with a pointer which are 1. Get the pointer 2. Evaluate the pointer 3. Put the pointer 1. Get the pointer. To get the pointer I looked into my SloshingTank2D contolDict file where I used probes function to obtain pressure. This function creates a P file postprocessing folder. Code:
functions { probes { type probes; libs ("libsampling.so"); writeControl writeTime; probeLocations ( (0 .29 -0.04) (0 -.29 -0.04) ); fixedLocations false; 2. Evaluate the pointer: I have my Matlab interpolation code in .m file format in which utility file I can connect it. 3. Put the pointer: The solidBodyMotionFunction provides a utility where the solid body motion can be read from text file. Can I modify tabulated6DoFMotion utility function such that the Matlab writes the files at each time step and FoamSolver reads the file at each time step? I have looked into the tabulated6DoFMotion.H file and tabulated6DoFMotion.C file in which line I should provide the pointer such that Code:
#include "tabulated6DoFMotion.H" #include "addToRunTimeSelectionTable.H" #include "Tuple2.H" #include "IFstream.H" #include "interpolateSplineXY.H" #include "unitConversion.H" // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace solidBodyMotionFunctions { defineTypeNameAndDebug(tabulated6DoFMotion, 0); addToRunTimeSelectionTable ( solidBodyMotionFunction, tabulated6DoFMotion, dictionary ); } } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::solidBodyMotionFunctions::tabulated6DoFMotion::tabulated6DoFMotion ( const dictionary& SBMFCoeffs, const Time& runTime ) : solidBodyMotionFunction(SBMFCoeffs, runTime) { read(SBMFCoeffs); } // * * * * * * * * * * * * * * * * Destructor * * * * * * * * * * * * * * * // Foam::solidBodyMotionFunctions::tabulated6DoFMotion::~tabulated6DoFMotion() {} // * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * // Foam::septernion Foam::solidBodyMotionFunctions::tabulated6DoFMotion::transformation() const { scalar t = time_.value(); if (t < times_[0]) { FatalErrorInFunction << "current time (" << t << ") is less than the minimum in the data table (" << times_[0] << ')' << exit(FatalError); } if (t > times_.last()) { FatalErrorInFunction << "current time (" << t << ") is greater than the maximum in the data table (" << times_.last() << ')' << exit(FatalError); } translationRotationVectors TRV = interpolateSplineXY ( t, times_, values_ ); // Convert the rotational motion from deg to rad TRV[1] *= degToRad(); quaternion R(quaternion::XYZ, TRV[1]); septernion TR(septernion(-CofG_ + -TRV[0])*R*septernion(CofG_)); DebugInFunction << "Time = " << t << " transformation: " << TR << endl; return TR; } bool Foam::solidBodyMotionFunctions::tabulated6DoFMotion::read ( const dictionary& SBMFCoeffs ) { solidBodyMotionFunction::read(SBMFCoeffs); // If the timeDataFileName has changed read the file fileName newTimeDataFileName ( fileName(SBMFCoeffs_.lookup("timeDataFileName")).expand() ); if (newTimeDataFileName != timeDataFileName_) { timeDataFileName_ = newTimeDataFileName; IFstream dataStream(timeDataFileName_); if (dataStream.good()) { List<Tuple2<scalar, translationRotationVectors>> timeValues ( dataStream ); times_.setSize(timeValues.size()); values_.setSize(timeValues.size()); forAll(timeValues, i) { times_[i] = timeValues[i].first(); values_[i] = timeValues[i].second(); } } else { FatalErrorInFunction << "Cannot open time data file " << timeDataFileName_ << exit(FatalError); } } SBMFCoeffs_.readEntry("CofG", CofG_); return true; } // ************************************************************************* // |
May 12, 2020, 16:19 |
Herpes Free Engineer
Rep Power: 12 |
- Would the following help? - https://www.precice.org/ - https://www.openfoam.com/documentati...alCoupled.html
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 13, 2020, 08:32 |
#3 | |
Santiago Lopez Castano
I dont find a good reason for coupling at all! Why don't you just re-implement whatever you are doing in matlab into an OpenFOAM class/library? Coupling codes is certainly more "difficult", from a programming standpoint, specially when you have to interface with commercial codes (MATLAB). BTW, using file pipes as means of coupling data-intensive codes is rather inefficient, slow, prone to IO errors, and you might run with caching/memory issues along the way. What is better to do in this cases is to program a DRIVER, a third program that interact directly with the codes you want to couple. One example of that is preCICE. |
May 13, 2020, 09:56 |
sreekanth
Rep Power: 6 |
I Thank HPE and Santiago for taking their precious time and reverting back.
I have seen the src files relating to 'spring', 'mass', 'damper' systems, which I can attach to my sloshingTank and run my simulations. But my goal is to derive the equation of motion flutter derivatives using Matlab which I guess would be difficult to frame in OpenFOAM. To do this I am trying to couple the two systems with the basic equation of motion as my first step. With HPE's advice, I am looking into the preCICE. Also, I have one more query. Instead of Matlab can I use Python script as I have seen OpenFOAM env supports pyFOAM. If so how can I add my class/library files in OpenFOAM using python? For example: Here in my case, I have my probes function which calculates pressure to should be taken by python/Matlab and return the values to OpenFOAM in dynamic library dictionary files. If there is some possibility it would be really helpful if someone shares the manual/URL using pyFOAM. |
May 13, 2020, 10:34 |
#5 | |
https://github.com/muzuka/MassSpringSystem Or you can implement it directly, for instance: http://www.tfd.chalmers.se/~hani/kur...FoamReport.pdf In any case, its just an additional set of ODEs solved over the surface of your airfoil, calculating displacements and rotations: https://perso.limsi.fr/olm/archives/flutter.pdf Which lays in the very reasons as to why OpenFOAM exists. Anyway, you decide whether it's worth to implement it there, or not. Note that your code will be inevitably slowed down by the blocked communications caused by the preCICE driver. If you are doing toy simulations it may not be a problem though... In any case it'd be nice to see the implementation of such coupling. If there is a library that can do what you look for in Python, in 99.99999999999% of the cases that library is either written in C/C++ or it also exists in C/C++, so you can avoid python altogether. And to answer your question, yes, you may try swak4foam as a means of importing/exporting (piping) your data as well. |
May 13, 2020, 17:01 |
Rep Power: 12 |
- For data transfer from OpenFOAM, I suggest Ofpp, which is a bliss in my opinion in comparison to PyFoam. Hope this helps.
Coupling between CFX and Matlab | Skymaas | CFX | 3 | April 13, 2020 19:58 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
