Coding issue / OpenFOAM
Like Tree2Likes
  • 1 Post By hk318i
  • 1 Post By hk318i
Old   June 30, 2016, 14:49
Default Coding issue / OpenFOAM
SinaJ
sina_mech is on a distinguished road
I'm trying to compile a solver. I have several functions that those functions want to access some mesh data, and I would like to keep those functions in separate C files, and having access in main C file via header files. Please see "testme.C" below! I get errors, cuase I can't access to 'vector', 'label', 'mesh', and etc. How can I fix that?
Example (I know the purpose of the function doesn't make sense ... but it's just an example!)
// testme.C file
double TestMe(std::vector <double> & myvec)
	vector myPoint(1.0, 1.0, 1.0);
	label myCell = mesh.findCell(myPoint);
	double u_here = U[myCell].component(0);
	return u_here;
// testme.h file
double TestMe(std::vector <double> & myvec);
// mySolver.C file
int main(int argc, char *argv[])
	std::vector <double> myvec;
	double x_com = TestMe (myvec);
sina_mech is offline   Reply With Quote
Old   June 30, 2016, 17:43
SinaJ
Any suggestions would be really helpful
Old   July 4, 2016, 08:25
Hassan Kassem
hk318i is on a distinguished road
Your code has some major issues, I will try to highlight the main problems;
  • The data types like label, scalar and vector are not available because the header files are not included.
  • The variable ``mesh`` is not available within the function scope. You may need to pass a reference to it.
  • You are mixing between std C++ data types and OpenFOAM which is not a good practice and could cause some problems later.
  • Creating functions or classes and compile them directory with a solver is not OpenFOAM style.
  • OpenFOAM has few utilities which create header, source and application files which follow OpenFOAM style. (foamNew, foamNewBC, foamNewSource, foamNewApp, foamNewCase, foamNewTemplate)
Here is a minimal example,
//fun.H
#ifndef fun_H
#define fun_H
#include "scalar.H"
#include "vector.H"
namespace Foam
    vector TestMe(const vector& myvec);
#endif
//fun.C
#include "fun.H"
Foam::vector Foam::TestMe(const vector& myvec)
    Info<< "Hello from TestMe" << endl;
    Info<< "vector: " << myvec << endl;
    Info<< "vectorXcmpt: " << myvec.component(0) << endl;
    Info<< "vectorYcmpt: " << myvec.component(1) << endl;
    Info<< "vectorZcmpt: " << myvec.component(2) << endl;
    return myvec;
//exApp.C
#include "fun.H"
using namespace Foam;
    vector A(1,2,3);
    vector B(4,5,6);
    vector a = TestMe(A);
    vector b = TestMe(B);
    Info<< "Hello from the main()" << endl;
    Info<< "vector a: "  << a << endl;
    Info<< "vector b: "  << b << endl;
    return 0;
//Make/files
fun.C
exApp.C
EXE = $(FOAM_USER_APPBIN)/exApp
and you can leave Make/options empty for this case but for a basic case you may need something like this
//Make/files
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools
I know it looks very long for minimal example but that is how C++ works.
Best wishes,
Hassan
sina_mech likes this.
@HIKassem | HassanKassem.me
hk318i is offline   Reply With Quote
Old   July 6, 2016, 11:52
SinaJ
//fun.H
#ifndef fun_H
#define fun_H
#include "scalar.H"
#include "vector.H"
namespace Foam
#endif
//fun.C
#include "fun.H"
    return myvec;
//exApp.C
#include "fun.H"
    vector A(1,2,3);
    vector B(4,5,6);
    return 0;
//Make/files
fun.C
exApp.C
//Make/files
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools
Best wishes,
Hassan
Hi Hassan,
Thank you for your reply I know i would be better to stick to openFoam's protocols, but in a case, I tried this out, and seems to be working:
//myOwnCFile.C
#include "fvMesh.H"
#include "fvCFD.H"
void MyFunction(std::vector<double> & test, fvMesh const& mesh, vectorField & U)
In the function above, I use mesh and velocity field (U) as variables by passing a reference to it. What do you think about it?
Old   July 6, 2016, 13:10
Hassan Kassem
It is up to you to use std C++ or not. If you are passing a value by refrence and not planning to change the variable within the function or class, use ``const`` identifier.
void MyFunction(const std::vector<double>& test, const fvMesh& mesh, const vectorField& U)
Old   September 14, 2022, 22:44
chengan.wang
wangchengan2003 is on a distinguished road
Send a message via Skype™ to wangchengan2003
Dear Hassan,
I want to create some functions in the solver. I have tested the code you proposed. They are correct perfectly.
I just want to replace the fun.H file by
template<class CloudType>
inline const Foam::tmp<Foam::volVectorField>
Foam::KinematicCloud<CloudType>::UPar() const
    tmp<volVectorField> tUPar
        volVectorField::New
            this->name() + ":UPar",
            mesh_,
            dimensionedVector(dimVelocity, vector(0,0,0)),
            extrapolatedCalculatedFvPatchVectorField::typeName
    volVectorField& UPar = tUPar.ref();
    forAllConstIter(typename KinematicCloud<CloudType>, *this, iter)
        const parcelType& p = iter();
        const label celli = p.cell();
        UPar[celli] += (p.U())/(p.nParticle());
    UPar.primitiveFieldRef() /= 1;//mesh_.V();
    UPar.correctBoundaryConditions();
    return tUPar;
inline const Foam::tmp<Foam::volScalarField>
Foam::KinematicCloud<CloudType>::SumPar() const
    tmp<volScalarField> tSumPar
        volScalarField::New
            this->name() + ":SumPar",
            mesh_,
            dimensionedScalar(dimless, 0),
            extrapolatedCalculatedFvPatchScalarField::typeName
    volScalarField& SumPar = tSumPar.ref();
        SumPar[celli] += p.nParticle();
    SumPar.primitiveFieldRef() /= 1;//mesh_.V();
    SumPar.correctBoundaryConditions();
    return tSumPar;
from Lagrangian data - particle velocity post processing
such as
//fun.H
#ifndef fun_H
#define fun_H
        volVectorField::New
            mesh_,
    return tUPar;
        volScalarField::New
            mesh_,
    return tSumPar;
#endif
And I don't use fun.C file. After compiling, there are some mistakes;
fun.H:16:41: error: no ‘const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::KinematicCloud<CloudType>::UPar() const’ member function declared in class ‘Foam::KinematicCloud<CloudType>’
fun.H:48:43: error: no ‘const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::KinematicCloud<CloudType>::SumPar() const’ member function declared in class ‘Foam::KinematicCloud<CloudType>’
I think I need to add some codes in fun.H. Could you give me some suggestions?
Best regards,
Chengan
wangchengan2003 is offline   Reply With Quote
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 19:00
OpenFoam parallel running log issue clktp OpenFOAM Running, Solving & CFD 2 January 19, 2016 09:12
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 02:00
Issue installation OpenFOAM - libopen-rte.so.0 Voyage_gui OpenFOAM 1 August 12, 2011 03:46
