Rotate a field
Old   January 27, 2023, 09:42
Default Rotate a field
vtAM is on a distinguished road
Ive been reading this forum a lot and have drawn many useful information for developing my new solver. Close to finishing, I am now stuck and looking for some help.
What I want to do: I want to rotate the components of a vector respectively a tensor field. By rotation I mean just rotate the vectors or tensor by changing theirs components. I dont want to rotate the mesh here nor do I want to change the cell center locations or anything.
What I do have:
  • The reference to the mesh "mesh_"
  • A quaternion "rotationquaternion" that describes the rotation i want to perform
This is my code:
            // Print a vector before rotation (debugging)
             Info<<mesh_.lookupObjectRef<volVectorField>
                "U"
            ).ref()[1] << nl << endl;
            // Rotation to be performed
            vector rotaxis(0, 0, 1);        // about z axis
            scalar rotangle(3.14159/2.0) ; // around 90°
            quaternion rotationquaternion(rotangle,rotaxis);
            // Perform rotation
            Foam::transform
                rotationquaternion,
                    "U"
                ).ref()
            // Print a vector after rotation (debugging)
                "U"
However, the first vector of the field I print out to check if the transformation was done remains unchanged. The output I get:
(-3.89156e-05 1.63329e-05 -2.96595e-05)
The output I want:
(-1.63329e-05 -3.89156e-05 -2.96595e-05)
I need to use the lookup because later on I want to rotate any field (not just "U") dynamically without hardcoding their names.
Any help is highly appreciated! Thank you!
vtAM
vtAM is offline   Reply With Quote
Old   January 27, 2023, 11:31
Just managed to solve. This is working as inteded:
                "U"
            ).internalField()[678] << nl << endl;
            scalar rotangle(M_PI_2) ; // 90°
            quaternion rotationquaternion(rotaxis, rotangle);
            Info<< "quaternion " << rotationquaternion << nl << endl;
            // Perform rotation
            Foam::transform
                    "U"
                ).ref(),
                rotationquaternion,
                    "U"
                ).internalField()
                "U"
There are three changes made.
  1. Correct initialization of the quaternion. The axis goes first, the angle second
  2. Use internalField() instead of ref(). Both work, but internalField() is a static reference and recommended for speed, see src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricField.H
  3. Use Foam::transform(ref to field, quaternion, ref to field) to actual change the field itself. I am not a C++ pro but from my understanding the previous Foam::transform(quaternion, ref to field) would only return a copy of the rotated field.
Hope this helps someone in the future. Thanks to everybody who was about to help.
Cheers,
vtAM
Initial pressure field from velocity field (incompressible) dhein STAR-CCM+ 3 January 18, 2022 08:12
turbulence field omega stops solver woodie OpenFOAM Pre-Processing 1 January 9, 2022 10:42
Implement field function with data from previous time steps as boundary condition Faraam STAR-CCM+ 0 August 20, 2021 15:33
potential flows, helmholtz decomposition and other stuffs pigna Main CFD Forum 1 October 26, 2017 08:34
[General] How to create an additional vector with {Field 4, Field 5, Field 6} Bombacar ParaView 1 August 15, 2015 18:05
