June 8, 2013, 09:31 |
how to see boundary layer flow?
Ehsan
Rep Power: 26 |
Hi
I have a as seems simple question. can we expect that boundary layer be visible in the flow? I have a flow in a tube like shock tube(but 2D).but I can't see the boundary layer.is it a trouble with mesh?I have set y+ around 30.or its not a rationale expectation? thanks.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
June 9, 2013, 08:11 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
"See the boundary layer" in what sense? Do you mean that you expect to see the U profile along a plot line in a cross-section of the tube? Can you show an image of the profile you're seeing? Including a snapshot of the mesh? Best regards, Bruno
June 9, 2013, 08:42 |
Ehsan
Rep Power: 26 |
Hi
I want to know if the boundary layer has resolved well or not(it originated at all or not)
June 9, 2013, 10:54 |
#4 | |
Bruno Santos
Rep Power: 128 |
Caution: I might be wrong here, but the following is what I vaguely know on this topic!
I thought that the wall function is meant to compensate for not being possible to solve the boundary layer!? In other words, isn't it this why there are wall functions in the first place? Namely because we cannot spend too much memory/computation time solving the boundary layer directly with an ultra fine mesh near the wall? And that the reason why y+ is used as a reference is precisely so that we can use the wall function to sort-of replace the better estimated boundary layers? (The "log" and the "viscous" ones, I think...) At least this is what I've understood from here:
Last but not least, if I'm not mistaken, the only way to figure out if the boundary layer is at least properly approximated, without experimental data, would be to rely on DNS modelling: Quote:
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 17:35 |
Boundary Layer roughness/ low reynolds wall treatment | Luigi_ | STAR-CCM+ | 1 | March 14, 2012 08:40 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
Unsteady Boundary Layer Flow | Wen Long | Main CFD Forum | 0 | July 29, 2002 23:08 |
