June 26, 2013, 12:23 |
twoPhaseEulerFoam - Liquid-solid simulation
Bayard Morales
Hello there.
I am modeling a liquid-solid (water + solids) system, following the data from Cornelissen, J. T., Taghipour, F., Escudié, R., Ellis, N., & Grace, J. R. (2007). CFD modelling of a liquid–solid fluidized bed. Chemical Engineering Science, 62(22), 6334–6348. My goal is to validate solver twoPhaseEulerFoam for this system and later on employ it for different conditions. First, I am trying to disregard completely any particle-particle interaction, so both kineticTheory is off and G0 (ppProperties) is set to 0. I have started working on this using the bed tutorial as a base, but my results are not very encouraging so far. Basically, the solid phase is always blown away from the domain - just as seen in the pictures (time in seconds). Does anyone have experience in modeling liquid-solid with this solver? Any advice? I have made a simple test - using exactly the same modeling, but with lower fluid density, the solid fraction is not blown away. Regards! |
multiphase modelling, openfoam 2.2.0 |
Modeling solidification/melting when a solid metal injected into liquid steel | Raijin Thunderkeg | FLUENT | 1 | November 27, 2012 21:24 |
Heat transfer simulation of Gel(high viscous fluid) on a solid plate | fshak92 | STAR-CCM+ | 0 | October 26, 2012 12:42 |
Solid Properties Setup In Simulation of Porous Media | Modest Cat | FLUENT | 4 | March 26, 2012 05:00 |
liquid decreases in bubble column E-E simulation | jhchen | ANSYS | 1 | August 3, 2010 10:49 |
Shacking CAN VOF HEAT LIQUID SOLID | Optixxx | FLUENT | 0 | July 30, 2005 11:42 |
