Floating point exception (core dumped)
Old   September 21, 2013, 16:12
Default Floating point exception (core dumped)
Marcelo
marcelorl is on a distinguished road
I am new in OpenFOAM and trying to solve the flow in a labyrinth seal. First I created the mesh in ansys and the mesh looks fine, I don't think that is the problem. anyway, I've got the problem bellow and i am not finding how to solve. Thank you very much in advance for the help.
Starting time loop
Time = 2.4
Courant Number mean: 5.31745e+112 max: 3.29092e+117
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/icoFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Best Regards,
Marcelo Lopes
marcelorl is offline   Reply With Quote
Old   September 21, 2013, 16:21
Lieven
Lieven will become famous soon enough
Hi Marcelo,
Ok, the reason that you get this error is that your courant number is huge. So first step is to find out why this is. My first guess would be it's either a mesh-problem or an initial condition problem. So could you post the output of checkMesh here?
Could you describe your case a bit (geometry, boundary conditions, ...)
Regards,
L
Lieven is offline   Reply With Quote
Old   September 21, 2013, 16:58
Marcelo
Originally Posted by Lieven View Post
Hi Marcelo,
Regards,
L
As I am just starting the simulation, I am using IcoFoam solver. I am sending you a link with the simulation documents, if you have time to take a look I will be very grateful.
link: https://www.dropbox.com/sh/heth1ej26e7cz2m/ZrmtMgi9hd
Thank you very much
Marcelo
Old   September 22, 2013, 13:35
Marcelo
HI All,
I still having the problem with courant number, I will put below the checkMesh and my boundaries conditions:
| \\ / O peration | Version: 2.2.0 |
| \\/ M anipulation | |
Build : 2.2.0-5be49240882f
Exec : checkMesh
Date : Sep 22 2013
Time : 14:23:32
Host : "marcelo-VirtualBox"
PID : 3169
Case : /home/marcelo/Desktop/opt/openfoam220/tutorials/incompressible/icoFoam/2Drefinelwall001
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
internal points: 35544
faces: 1309746
internal faces: 1046042
cells: 588947
faces per cell: 4
boundary patches: 5
point zones: 0
face zones: 1
cell zones: 1
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 588947
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
inlet 126 88 ok (non-closed singly connected)
outlet 126 88 ok (non-closed singly connected)
lowerwall 7488 4996 ok (non-closed singly connected)
upperwall 24048 16036 ok (non-closed singly connected)
frontandback 231916 121258 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.0043412 0 0) (0.00577688 0.00238696 1e-05)
Mesh (non-empty, non-wedge) directions (1 1 1)
Boundary openness (-8.9769e-19 4.84392e-18 1.16378e-18) OK.
Max cell openness = 2.5555e-16 OK.
Max aspect ratio = 8.93804 OK.
Minimum face area = 3.23357e-12. Maximum face area = 3.66475e-10. Face area magnitudes OK.
Min volume = 4.44352e-18. Max volume = 1.10704e-15. Total volume = 1.65589e-10. Cell volumes OK.
Mesh non-orthogonality Max: 72.3617 average: 30.7772
*Number of severely non-orthogonal faces: 8.
Non-orthogonality check OK.
<<Writing 8 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 3.77461 OK.
Coupled point location match (average 0) OK.
Mesh OK.
Boundary Condition:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
upperwall
type fixedValue;
value uniform (0 0 0);
lowerwall
type fixedValue;
frontandback
type empty;
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type fixedValue;
value uniform 100;
outlet
type fixedValue;
value uniform 50;
upperwall
type zeroGradient;
lowerwall
type zeroGradient;
frontandback
type empty;
How big should be the courant number for this case?
Thank you very much
Regards,
Marcelo
Old   September 22, 2013, 13:55
Lieven
Hi Marcelo,
There is an inconsistency between your mesh and your boundary conditions. According to the checkMesh, you don't have an empty direction
but you define an empty boundary condition in the U and p files.
Can you post the polyMesh/boundary file too?
Could you post an image of your mesh from a few different angles?
Cheers,
Lieven
Old   September 22, 2013, 14:25
Marcelo
Hi Marcelo,
Cheers,
Lieven
Hi Lieven,
Thank you very much for you help and sorry to be beginner and without any openfoam skills. This mesh was done in ansys and exported to openfoam. As openfoam only recognize 3d mesh, I generate the mesh with the 3rd direction very thin and called the front and back wall as "empty". FInd below the boundary file, and as I told, it was generated in ansys and I don’t have a polymesh file, but big files in the polymesh directory.
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
5
inlet
type patch;
nFaces 126;
startFace 1046042;
outlet
type patch;
nFaces 126;
startFace 1046168;
lowerwall
type wall;
nFaces 7488;
startFace 1046294;
upperwall
type wall;
nFaces 24048;
startFace 1053782;
frontandback
type empty;
nFaces 231916;
startFace 1077830;
File Type: jpg Screenshot from 2013-09-22 15:10:00.jpg (89.5 KB, 25 views)
File Type: jpg Screenshot from 2013-09-22 15:10:42.jpg (59.5 KB, 23 views)
Old   September 22, 2013, 14:53
Lieven
Hi Marcelo,
Is the mesh effectively 1 cell deep in the 3th dimension? It's not possible to see this based on the pictures you provided. I have the feeling it is not, since the checkMesh doesn't recognize it as such.
Just as an experiment, could you change the 'empty' to 'patch' in the polyMesh/boundary file, the 'empty' to 'slip' in the U and p file and run the case again (as a 3D case)?
Cheers,
L
Old   September 22, 2013, 15:31
Marcelo
Hi Marcelo,
Cheers,
L
You are right about the cell deep, it had more than 1. but I tried to change the boundary to slip and the empty to patch, and run as a 3D case, but still not working. I will paste here the courant number and the error again:
Time = 0.7
Courant Number mean: 4.30227e+39 max: 7.87172e+45
DILUPBiCG: Solving for Ux, Initial residual = 0.831977, Final residual = 78717.3, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 0.917538, Final residual = 782.374, No Iterations 1001
DILUPBiCG: Solving for Uz, Initial residual = 0.95876, Final residual = 243.126, No Iterations 1001
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::DICPreconditioner::DICPreconditioner(Foam::l duMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::lduMatrix::preconditioner::addsymMatrixConst ructorToTable<Foam::DICPreconditioner>::New(Foam:: lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/icoFoam"
at icoFoam.C:0
#11
#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13
marcelo@marcelo-VirtualBox:~/Desktop/opt/openfoam220/tutorials/incompressible/icoFoam/2Drefinelwall001$
Thank you again for the help.
Regards,
Marcelo
Old   September 22, 2013, 15:39
Lieven
Ok, but at least it is running and we identified the problem i.e. the mesh.
The reason it fails after solving for Uz is that the pressure matrix will be horribly conditioned because of the huge Co and the 1001 iterations (simply Nmax) it needs for solving the velocity vector.
So first things first:
* remake your mesh and import it properly so that it really is a 2D mesh. I suggest to search this forum if you need help on this. I don't expect you to be the first one to have this problem.
* Consider using hex cells instead of tets. From what I can see, the geometry is rather simple and this will improve both convergence and accuracy
* checkMesh should show a line like
Mesh (non-empty) directions (1 1 0)
or (1 0 1) or (0 1 1). Not (1 1 1)
Good luck!
L
Floating point exception with pimpleDyMFoam ebah6 OpenFOAM Running, Solving & CFD 9 November 1, 2017 05:58
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 10:21
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 03:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
