help! kOmega SST SAS always using RANS?
Old   March 16, 2016, 08:51
Default help! kOmega SST SAS always using RANS?
kingjewel1 is on a distinguished road
Dear all,
I'm trying to simulate flow over 9 surface mounted cubes at Re:4e5
One cube has 2 windows so it's definitely an unsteady problem
My deltaT is 1-e4.What is the recommended yplus?
But also it looks like it's always using RANS rather than LES for vortex shedding so looks averaged out. What am I doing wrong?
Pics: https://onedrive.live.com/redir?resi...nt=photo%2cpng
Mesh: https://onedrive.live.com/redir?resi...nt=photo%2cpng
A full executable case is here: https://onedrive.live.com/redir?resi...hint=folder%2c
kingjewel1 is offline   Reply With Quote
Old   April 14, 2017, 08:13
Lukas Lebovitz
lukas.lebo is on a distinguished road
Did you ever find out how to set up the kOmega SST SAS Case properly? If yes could you provide an example?
lukas.lebo is offline   Reply With Quote
Old   March 13, 2018, 03:46
Thorben Schröder
Chief-CeTe is on a distinguished road
in my SAS cases, one problem was often that the omega equation initial residual was so low that the omega equation was not iterated at all. Using minIter for omega in the fvSolution solved the problem and I got rid of the Rans-like behavior.
Hope it helps,
Cete
Chief-CeTe is offline   Reply With Quote
k-w SST SAS for compressible solvers eddykendo OpenFOAM 2 June 25, 2019 15:57
FSAS coefficient in k-omega SST SAS model vkrastev OpenFOAM Running, Solving & CFD 9 October 25, 2018 08:09
RANS FX63-137 kOmega SST model PierluigiRossi SU2 2 June 24, 2016 05:56
Post processing in SAS SST arunintn FLUENT 0 June 8, 2013 14:12
Free shear flow LES/DES, SAS, RANS laxwendrofzx9r Main CFD Forum 2 March 24, 2013 04:45
