when i scale down the down the geometry i get unrealistic result.what is the problem?
Like Tree2Likes
  • 1 Post By RobertHB
  • 1 Post By kandelabr
Old   July 30, 2018, 06:27
Default when i scale down the down the geometry i get unrealistic result.what is the problem?
rupak504's Avatar
Lolita
rupak504 is on a distinguished road
I am using Ubuntu -14.04, OpenFOAM-4.0, model- multiphaseInterFoam- DamBreak4phase.
I get the result when i use the tutorial as it is, problem starts when i scale down the geometry from metres to millimetres, i get unrealistic results. What could be the problem?
rupak504 is offline   Reply With Quote
Old   July 30, 2018, 11:02
Robert
RobertHB is on a distinguished road
How do you "scale down"? Did you remember to scale your dimensionless groups accordingly?
rupak504 likes this.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   July 31, 2018, 06:39
rupak504's Avatar
Lolita
I will post the videos of the two cases. Then you give me the feedback
Old   July 31, 2018, 07:27
Robert
That's a beginning, but the more interesting informationen would be
  • What do you want to simulate?
  • How does your simulation setup look like?
  • Which parameters do you need for your simulation? Please name them and their value for both scales.
  • Which solver are you using?
Anything that may help us to help you. A video is only a small help, if any, i guess.
Last edited by RobertHB; August 1, 2018 at 03:00. Reason: Edited bullet point 3 to not only ask for parameters but also for their values on both scales.
Old   July 31, 2018, 07:36
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
Release a droplet on the table or pour a bucket of water on the floor - the result isn't the same.
You have to keep Reynolds number when scaling cases (geometry/viscosity/velocity). In any case, some results will scale linearly, other results won't...
SRKR likes this.
kandelabr is offline   Reply With Quote
[ICEM] Problem Meshing Asymmetrical Geometry Madhatter92 ANSYS Meshing & Geometry 1 December 23, 2017 05:56
[ANSYS Meshing] Scale geometry but mesh size to remain same sangrampp ANSYS Meshing & Geometry 1 February 12, 2016 05:19
[Workbench] Problem to select facing when updating geometry vbernard ANSYS Meshing & Geometry 1 October 28, 2013 09:18
[Gmsh] Problem with geometry. Andrea_85 OpenFOAM Meshing & Mesh Conversion 1 January 6, 2011 08:34
Scale Problem and Moving Walls in PCube/TGrid/Fluent Christian Tollschein Main CFD Forum 8 September 17, 1999 13:01
