Paolo Vescovo
Rep Power: 0 ![]() |
Good evening, i am new in this forum.
I am trying to implement and chtMultiRegionFOAM-solve a thermal contact problem between two solids in OpenFOAM 2.3.0 (due to some troubles between ParaView and the OpenGL that suit my PC graphic card, troubles i am working about too). The undesired result is that it seems to me that the simulation just does not start and with no visibile log to me. Is there a way to make the solver output what is going on in detail? Here attached You can find two archives: the only difference i expect You to find is that in version 01 distinct nodes coincide at the same points in the space on the boundary between the two solids while in version 02 every space point hosts one node. |
Retired Super Moderator
Bruno Santos
Rep Power: 129 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings Paolo and welcome to the forum!
I've only looked at the case "01" and there are two problems with it:
As for the problems with OpenGL, I know that you are using blueCFD-Core 2.3-1 from emails we have exchanged in the past and due to the log files in the cases you attached. Therefore, you can install a more recent blueCFD-Core version (2016-2 or 2017-2) that provides a more recent version of OpenFOAM (4.x and 5.x, respectively) that has this bug fixed. Then you can install another version of ParaView, namely version 4.4, by following the instructions provided here: http://bluecfd.github.io/Core/FAQ/ho...n-of-ParaView/ Best regards, Bruno
Display Modes | |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 02:39 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
