January 23, 2020, 08:35 |
Maxwell viscoelastic Model not working
Aehrnz
I'm trying to run a case with the viscoelasticFluidFoam solver and the Maxwell viscoelastic Model. I took the Oldroyd-B Tutorial Case and just swapped the model to Maxwell inside the viscoelasticProperties.H file. Unfortunately the case doesn't run and i get this error message: ----------------------------------------------------------------------------------------------------------------- BiCGStab: Solving for Ux, Initial residual = 1, Final residual = 1.12431e-10, No Iterations 1 BiCGStab: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 CholeskyPCG: Solving for p, Initial residual = 1, Final residual = 9.58019e-08, No Iterations 319 time step continuity errors : sum local = 1.66912e-13, global = 3.42652e-16, cumulative = 3.42652e-16 --> FOAM FATAL ERROR: lowerPtr_ or upperPtr_ unallocated From function lduMatrix::lower() const in file matrices/lduMatrix/lduMatrix/lduMatrix.C at line 205. FOAM aborting ---------------------------------------------------------------------------------------------------------------------------- I have tried foam extended 3.1 and 4.1 with the same approach but the error is the same for both. Since then i also tried different solvers and preconditioners in the fvsolutions file, but with no difference. Do i miss something obvious? Thanks, Aehrnz |
April 23, 2020, 03:33 |
#2 | |
Syavash Asgari
Rep Power: 18 |
I faced the exact same issue with linearMaxwell model. Did you overcome the problem? Kind regards, syavash |
April 25, 2020, 08:28 |
#3 | |
Aehrnz
I traced the Problem to the LU-Decomposition the solver is doing, but unfortunately couldn't find a solution. In my case I just continued with the Oldroyd-B model. Kind regards, Aehrnz |
viewFactor radiation model stuck | shach934 | OpenFOAM | 1 | May 25, 2021 11:01 |
viscoelastic model in dynamic mesh | Amir | OpenFOAM | 1 | November 28, 2017 09:55 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
DPM model w/ Wave model - errors in documentation | HS | FLUENT | 0 | April 12, 2006 04:37 |
