Mixing plane interfaces Openfoam 7.0
Like Tree1Likes
  • 1 Post By .bastian
Old   February 22, 2020, 08:37
Default Mixing plane interfaces Openfoam 7.0
Jonathan is on a distinguished road
Hi everyone,
I was wondering whether anyone knew whether there was an implementation of the mixing plane approach to rotor-stator interactions which had been implemented for OF.
I've been out of the OF loop for a little while and wondered there might have been some work on supporting these kinds of (turbomachinery) based problems in the meantime.
I think there was some work by some members for hydro turbine applications, but this was done on a fork (foam-extend) of the original project. if so, would anyone have a view as to how difficult / whether it would be tractable to port this code over (if it was finished) - thinking of other libraries / changes which might have been done in the extend-project which were not in the "original" OF repo's.
thanks a lot in advance for any input,
regards
jonathan
PS If this functionality is not available, is anyone currently using OF 7 project to do turbomachinery work and if so, how have you solved this problem for this (steady-state) approach . Thanks again in advance
Jonathan is offline   Reply With Quote
Old   February 26, 2020, 06:31
.bastian is on a distinguished road
Hi Jonathan,
Why don't you simply use foam-extend, which works quite well for turbomachinery applications?
I can imagine that a porting is not that easy.
As you have already noted the code base of both versions is quite different by now, including dependencies to other extensions made in foam extend.
regards .bastian
Jonathan likes this.
.bastian is offline   Reply With Quote
Old   March 2, 2020, 06:54
Thanks Bastion,
That seems like the most pertinent thing to do. I'll download it an have a play.
Much appreciated
Regards
Jonathan
cfd, frozen rotor, mixing plane, open foam, turbomachinery
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 09:17
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
What's mixing plane? zjvskobe Main CFD Forum 1 December 8, 2014 20:54
mixing plane & mesh interfaces amin.z FLUENT 0 June 24, 2014 01:28
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
