BuoyantSimpleFoam, freestream convergence, thermal wake
Old   July 7, 2020, 07:02
Default BuoyantSimpleFoam, freestream convergence, thermal wake
Henrik
broccolibadger is on a distinguished road
As has been the case lately with the buoyant solvers, results are looking alright but the residuals have a curious way of behaving that I can't seem to get my head around. It has to do with the p_rgh residual not stabilizing and decreasing, even though the flow is qualitatively/apparently converged.
Is there a mistake in my case setup or is this the way it's supposed to be?
The case is a simple heat source in a free stream 2D compressible laminar flow (no gravity), see attached image.
First I assumed the boundary conditions do not permit convergence though I haven't been able to find any combination that alleviates the residual behavior.
I've tried running it with PISO and PIMPLE with similar issues for the residual.
Files for boundary conditions, fvSchemes, fvSolution below:
p_rgh:
internalField   uniform $pAtm;
boundaryField
    inlet
        type            freestreamPressure;
        freestreamValue uniform $pAtm;
    outlet
    walls
U:
internalField   uniform (0.01 0 0);
boundaryField
    inlet
        type            freestreamVelocity;
        freestreamValue uniform (0.01 0 0);
        value           $internalField;
    outlet
    walls
T:
internalField   uniform 291.45;
boundaryField
    inlet
        type            inletOutlet;
        inletValue      uniform 291.15;
        value           uniform 291.15;
    outlet
        type            inletOutlet;
    walls
        type            inletOutlet;
fvSchemes:
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
//    default         cellMDLimited Gauss linear 0.5;
//    default       cellMDLimited leastSquares 0.5;
divSchemes
    default         none;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
    div(phi,U) Gauss vanLeerV;
//    div(phi,K)     Gauss limitedLinear 1;
//    div(phi,h)     Gauss limitedLinear 1;
    div(phi,K)     Gauss linearUpwind grad(K);
    div(phi,h)     Gauss linearUpwind grad(h);
//    div(phi,T)     Gauss limitedLinear 1;
    turbulence Gauss upwind;
//    turbulence Gauss limitedLinear 1;
    div(phi,k) $turbulence;
    div(phi,omega) $turbulence;
    div(phi,epsilon) $turbulence;
laplacianSchemes
    default          Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default           corrected;
wallDist
    method exactDistance;
fvSolution:
solvers
    cellDisplacement
        solver          GAMG;
        smoother        GaussSeidel;
        tolerance       1e-7;
        relTol          0.001;
    p_rgh
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-08;
        relTol           0.01;
    "(T|U|h|k|epsilon|omega)"
        solver          PBiCGStab; //smoothSolver; PBiCGStab;
        //smoother        DILUGaussSeidel;
        preconditioner  DILU;
        tolerance       1e-08; // refine after some time to 1e-8
        relTol          0.001;
SIMPLE
    nNonOrthogonalCorrectors 2;
    consistent yes;
    residualControl
        p_rgh           1e-5;
        U               1e-5;
        h               1e-5;
        "(k|epsilon|omega)" 1e-4;
relaxationFactors
    fields
        rho             1;
        p_rgh           0.7; // 0.3;
    equations
        U               0.2;
        h               0.6;
        "(k|epsilon|omega|R)" 0.7;
thermophysicalProperties:
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
pRef    101325;
dpdt off;
mixture
    specie
        molWeight       28.96;
    thermodynamics
        Cp              1006;
        Hf              0;
    transport
        mu              1.8e-05;
        Pr              0.71;
Same behavior of residuals seem to be common on the forums.
broccolibadger is offline   Reply With Quote
simpleF, S-A, no convergence, sphere in air at re10^4 Alasir OpenFOAM 2 May 18, 2017 08:11
parallel code samiam1000 SU2 3 March 25, 2013 04:55
Anistropic thermal conduction in Fluent 6.2 Bharath FLUENT 0 November 23, 2006 21:07
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
