November 21, 2021, 07:01 |
My RAS kEpsilon model diverges
Leander Tielkes
Rep Power: 4 |
Hello FOAMers,
I am using RAS kEpsilon for an Atmospheric Boundary Layer simulation in order to calculate the mean wind speeds above a mountainous area. My domain is 3km long, 3km wide and 1.5km high. I first checked whether the model gives reasonable results and apparently it reproduces the measurement results from the Askervein Hill Project quite well. Currently I am trying to run a mesh convergence study. I wrote a script that runs the simulation over and over again each time with a finer mesh. However, for some mesh configurations, the solution suddenly diverges. I picked such a configuration that does not work and attached it as a .zip. Unfortunately the mesh was too large to upload, so I only have a screenshot of it. When I run simpleFoam (Build : _f815a12b-20210902 OPENFOAM=2106) the solution diverges, and at the 16th time step I get a floating point exception. The mesh seems to be okay. checkMesh prints "Mesh OK." Do you have an idea what is wrong here? Thank you in advance. Best regards, Leander |
November 23, 2021, 03:33 |
matej forman
Rep Power: 17 |
HI, you said it is a refined mesh, and you have 5 layers in the Z direction? I wonder how the coarse mesh looks like.
Your discretisation is pretty tight, can you post the log file with this FPO crash and checkMesh log as well? |
November 23, 2021, 03:39 |
Why don't you try boundary layer mesh?
November 23, 2021, 14:40 |
#4 | |
Leander Tielkes
Rep Power: 4 |
I have uploaded the two logs. Sorry about the lengthy log for simpleFoam, I am solving one time step at a time. |
November 23, 2021, 14:59 |
Leander Tielkes
Rep Power: 4 |
November 23, 2021, 16:43 |
matej forman
Rep Power: 17 |
There is one thing I do not understand. YOu are using simpleFoam, you run the case for a single iteration and you stop the case and then you restart the case running again a single iteration. Is there any reason for such an unusual solution strategy? Looking at the simpleFoam log, at iteration 10 your max velocity is too high which leads to excessive gradients and unphysical values of k and epsilon feeding momentum equation with too high Laplacian leading to continuity equation divergence.
What happens if you let your simpleFoam do it's work for a couple of hundreds of iterations? |
November 23, 2021, 23:15 |
Hello Leander,
I thought mesh should be the issue. I havent looked any of your files yet. Boundary layer mesh grow from the surface and used to analyze high gradients of temperature or momentum normal to a surface. Hope there is no error during compilation. Try to post your error message here. Irrespective of the mesh, have you tried to locate the error in your problem ? It's a good practice to run your problem in debug mode which locates your error exactly. This helps you in future to understand the code easily. Check this link, https://sites.google.com/site/foamgu...-debug-version Thank you |
November 26, 2021, 06:23 |
Leander Tielkes
Rep Power: 4 |
Hi Matej, I was solving step by step in order to monitor the convergence. I was doing it with a small script that postprocesses after every time step and decides whether the solution has converged. Since you asked, I did a bit of research and found that this can be done much simpler by using convergence criteria in openfoam. I switched to this method now. Unfortunately, letting openfoam run for ~500 timesteps does not stop it from diverging at timestep ~10, however the solution runs much faster now. Thanks for the advice!
Hi Kumar: I have attached a working minimal example that reproduces the error. It contains the mesh so if you like, you can check it yourself. It also contains the log and the error message. Thank you for the advice to switch to debug mode. However I feel uncomfortable rebuilding openfoam since I fear messing up things and ending up with no working installation of openfoam. I added a screenshot to show where the divergence starts. Depending on the mesh size it always seems to start at the top boundary. The fact that it starts at the edge towards the inlet might be a coincidence here. Here is my definition of the top boundary U: top { type fixedShearStress; tau (0.390796574 0 0); value uniform (0 0 0); } p: top { type zeroGradient; } k: top { type zeroGradient; } epsilon: top { type zeroGradient; } nut: top { type calculated; value uniform 0; } |
atmospheric bl, divergence, kepsilon, ras incompressible |
totalFlowRateAdvectiveDiffusive BC with RAS Model | EMM | OpenFOAM Running, Solving & CFD | 1 | April 25, 2019 05:45 |
VOF model + mixture model + RAS or LES model | ebtedaei | OpenFOAM Running, Solving & CFD | 23 | May 12, 2018 03:36 |
Make wall-function read a newly defined field inside modified kEpsilon model | Radunz | OpenFOAM Programming & Development | 2 | July 18, 2017 22:39 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
