Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Regarding the extraction of the data to further proceed with simulation scenarios
Old   July 17, 2021, 10:13
Post Regarding the extraction of the data to further proceed with simulation scenarios
Akshay
enthusiast is on a distinguished road
Dear FOAMers,
I have been working on the CFD simulation data for the Gravity settler which involves 3 phases (oil phase, mix phase and water phase). Here we used Euler-Euler multi fluid framework couples with Extended Quadrature Method of moments (EQMOM) to solve the population balance equation (PBE).
The gravity settler has 1 intel and 3 outlets, here the main purpose of using the gravity settler is to separate the costly catalyst from the product. From the CFD perspective, we are interested in the droplet-droplet interaction between the 3 phases.
I have data regarding the outlet mass flow rates (g/hr) and the temperature of the settler. Also, the density data of the liquid, which is dependent on settler temperature.
Alpha is the mass ratio of oil to oil and water and Gamma is the wt% of the mix phase (surfactant)
Some reference published papers are:
https://www.sciencedirect.com/scienc...63876217305920
https://www.jstage.jst.go.jp/article...ticle/-char/en
https://www.sciencedirect.com/scienc...44642356500085
I am interested in finding the volume fraction of each phase with respect to time, pressure of the outlets. How can I proceed with the data processing.
enthusiast is offline   Reply With Quote
write bc data and read it for other simulation jdp810 SU2 1 May 8, 2021 17:04
Simulation doesn’t proceed Anna Tian CFX 19 July 9, 2015 03:20
Exporting data of transient simulation DURING a simulation, at user locations ? Milan2013 CFX 0 April 18, 2014 03:47
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
