January 4, 2023, 13:16 |
Experimental verification
Jagan Mohan
Rep Power: 6 |
Hi All, I'm using multiPhaseEulerFoam in version 10 to simulate a laminar fluidized bed flow.
I've setup a CFD-DEM case using OpenFOAM-LIGGGHTS and able to capture what I see in lab experiments, both quality and quantity. When I do the same in multiPhaseEulerFoam, with settings adapted from laminar fluidized bed tutorial, the solver does not capture the basic flow hydrodynamics itself. We are well aware that there are a number of settings here and I started from a tutorial setup. Anyone has experience or ideas where to start from? Is it frictional or kinetic? Any publications, literature on tuning a solver are also helpful. Best, |
January 9, 2023, 04:21 |
January 18, 2023, 22:11 |
Jagan Mohan
Rep Power: 6 |
Hello Prof., thank you for this report. A quick question: on page 18, in 2D simulation using OpenFOAM, perhaps drum is rotating. Did you see "material" moving tangentially along drum circumference? (I'm having a setup in V10 multiphaseeulerfoam with moving boundary and I dont see any material moving in that direction. I'm thinking what could be issue?)
Could you please elaborate on this "A normal velocity with respect to the cylinder wall was defined as a boundary condition for the granular phase"? Thank you, |
January 23, 2023, 09:46 |
Jagan Mohan
Rep Power: 6 |
Hi Prof., thank you for your response. I'm rephrasing my question:
On page 18, is Figure 2-2 from 2D simulation using multiphaseEulerFoam? I'm curious about U.air (or liquid) and U.particles boundary condition on drum wall. Could you please share these details? Did you see "material" moving tangentially along drum circumference? I've raised another thread on issues I'm facing in multiphaseEulerFoam. Could you please take a look, whenever you get a chance? Moving wall not working in multiphaseEulerFoam Thank you, |
gas-solid flow, multiphaseeulerfoam, validations, verification |
How to find centrifugal pump CAD geometry with experimental results for benchmarking? | jgross | Main CFD Forum | 1 | October 18, 2021 12:47 |
Pump CAD + experimental data for CFD verification study | bemism | Main CFD Forum | 0 | July 20, 2017 15:30 |
Computed Pressure Drop is lower than experimental data | Ash Kot | FLUENT | 2 | May 17, 2017 09:41 |
Experimental & numerical results | Amy | CFX | 2 | September 1, 2005 08:52 |
Question Regarding Experimental Verification | Abhi | Main CFD Forum | 1 | June 18, 2002 13:48 |
