About the use of software FOAM
Old   January 9, 2005, 06:41
Default About the use of software FOAM
Li Yang
Hello all,
I am thinking to start to have a try on the software FOAM from the OpenFOAM web.
I downloaded OpenFOAM-1.0.General.gtgz from Other platforms ( and also from Sun Ultrasparc Solaris )since I have only got access to a Sun Solaris workstation(32bit). Unfortunately, I failed to decompress the file.
I tried the following options: tar -xvf OpenFOAM-1.0.General.gtgz
This gives me the error massage: tar: directory checksum error
Then I try to follow the instructions given by the OpenFOAM web, I use: tar xzf OpenFOAM-1.0.General.gtgz
This gives the following error message: tar: z: unknown option
Could anybody out there tell me what mistake I have made or what I should do please ? Thank you very much in adavnce.
Yours sincerely,
Li
Old   January 9, 2005, 08:21
Default Re: About the use of software FOAM
Jonas Larsson
try renaming the file to OpenFOAM-1.0.General.tar.gz
then do "gunzip OpenFOAM-1.0.General.tar.gz"
then do "tar -xfv OpenFOAM-1.0.General.tar"
hope that helps
Old   January 9, 2005, 10:12
Li Yang
Jonas,
Thank you very much.
It does work better. However, a error message appears at a certain stage:
OpenFOAM-1.0/doc/Doxygen/html/d0/d14/cellDecompCuts_8H-source.html, 13860 bytes, 28 tape blocks
Now I have got two directories :
\bin
\doc
under \doc I can see three sub-directories:
\Allwmake
\Doxygen
\Guides-a4
But I cannot see any Fortran source file. Why?
Your help will be very much appreciated.
Li
Old   January 9, 2005, 10:35
Praveen C
Download the file again from the openfoam website and try it.
Old   January 9, 2005, 16:56
Jonas Larsson
That is strange. If the gunzip worked I would expect the tar to work also. A download error would break the gunzip not the tar. Perhaps your disk is full so that your tar file got truncated?
Old   January 10, 2005, 03:22
matej
However, even if you untar succesfully, you'd never see any fortran in foam, as it is written in C++ ))
matej
Old   January 10, 2005, 17:12
jf
Is gnu tar available on (your) Solaris ? If yes, try running "gtar xzvf OpenFOAM-1.0.General.gtgz". The problem is perhaps due to a mismatch between tar versions.
Old   January 12, 2005, 16:12
Hrvoje Jasak
Yup, you need gnu tar - the one from Solaris has got hard-coded max path length and the directory structure of foam is too deep for foam.
Hrv
Old   May 16, 2009, 00:28
Default similar with ThirdParty.General.gtgz
Davin Scott
ollickle is on a distinguished road
Using Fedora,latest, changed OpenFOAM-1.5.General.gtgz to.tar.gz and
did tar xzf - all went well.
Same thing with ThirdParty.General.gtgz no good
tried gunzip no good.
So this file is neither tar nor gzip.
Excuse fumbles, am new at this Linux, just need it for real work!
ollickle
ollickle is offline   Reply With Quote
Old   November 2, 2009, 22:59
Default OpenFOAM Ubuntu Installation
Davin Scott
Changed from Fedora to try installation in Ubuntu 9.04,
need install instructions that work... please
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
