[General] Ordering XYZ data in Paraview
Like Tree2Likes
  • 1 Post By Gaetano
  • 1 Post By wyldckat
Old   October 28, 2013, 05:46
Default Ordering XYZ data in Paraview
Ellen van der Veer
ellenvdveer is on a distinguished road
I am pretty new to paraview and have a problem in converting my actual structured data into a structured grid. I have a pressure file showing X,Y,Z,P but the X,Y,Z data are not in structured order. I found out how to re-order one column, e.g. X data, but attached to that I need to have my Y and Z data to be sorted from low to high along with the sortedX data.
Does any of you know if Paraview can re-order the Y and Z data for the fixed order of X data? And if yes, how? Would be of great help!
Best,
Ellen
ellenvdveer is offline   Reply With Quote
Old   November 3, 2013, 06:08
Retired Super Moderator
Bruno Santos
Greetings Ellen and welcome to the forum!
If you could provide a small example, it would allow us to try to do some trial-and-error as well and to achieve the same you're trying to do.
Best regards,
Bruno
Old   November 4, 2013, 03:21
Ellen van der Veer
Thanks a lot. I just give a very straightforward example. E.g., you load a dataset representing X,Y,Z coordinates in PV which looks like this:
X Y Z
1 2 1
2 3 3
3 2 3
1 3 2
2 1 1
3 1 2
1 1 3
2 2 2
3 3 1
Now, I want it to sort in a structured way so I can convert it into a structured grid, i.e. it should look like this:
X Y Z
1 1 1
1 2 2
1 3 3
2 1 1
2 2 2
2 3 3
3 1 1
3 2 2
3 3 3
meaning that the X coordinates are sorted AND the Y,Z data are sorted within the block of the corresponding X-coordinate.
However, as far as I found out, I am only able to sort one column in Paraview, in this case the X-coordinate, which makes my result look like this:
X Y Z
1 2 1
1 3 2
1 1 3
2 3 3
2 1 1
2 2 2
3 2 3
3 1 2
3 3 1
Problem is that Paraview is not able to translate this into a structured grid. Very sorry if this all sounds a bit vague; it's just pretty hard to explain in words . Really hope you can help me on this!
Thanks
Old   November 5, 2013, 06:30
Gaetano
Gaetano is on a distinguished road
How about pre-processing your input file? I'm thinking about multiple sorting:
sort(z) -> sort(y) -> sort(x)
Before pre-processing (your example):
X	Y	Z
1	2	1
2	3	3
3	2	3
1	3	2
2	1	1
3	1	2
1	1	3
2	2	2
3	3	1
After sort(z):
X	Y	Z
1	2	1
2	1	1
3	3	1
1	3	2
3	1	2
2	2	2
2	3	3
3	2	3
1	1	3
After sort(y):
X	Y	Z
2	1	1
3	1	2
1	1	3
1	2	1
2	2	2
3	2	3
3	3	1
1	3	2
2	3	3
After sort(x):
X	Y	Z
1	1	3
1	2	1
1	3	2
2	1	1
2	2	2
2	3	3
3	1	2
3	2	3
3	3	1
I did this with m$ excel, but it should be straightforward with any software.
Another suggestion would be to create another field by merging the X, Y and Z and order by means of that. With decimal coordinates:
X	Y	Z
0.704	0.835	0.161
0.202	0.33	0.018
0.466	0.139	0.539
0.438	0.024	0.043
0.057	0.392	0.792
0.189	0.733	0.635
0.127	0.656	0.426
0.32	0.325	0.234
0.783	0.845	0.46
Here the new field is calculated as x*1000^3+y*1000^2+z*1000:
X	Y	Z	FIELD
0.704	0.835	0.161	704835161
0.202	0.33	0.018	202330018
0.466	0.139	0.539	466139539
0.438	0.024	0.043	438024043
0.057	0.392	0.792	57392792
0.189	0.733	0.635	189733635
0.127	0.656	0.426	127656426
0.32	0.325	0.234	320325234
0.783	0.845	0.46	783845460
After sorting:
X	Y	Z	FIELD
Which is the same result as sort(z) -> sort(y) -> sort(x)
Hope it helps.
Regards,
Gaetano
Gaetano is offline   Reply With Quote
Old   November 5, 2013, 07:40
Ellen van der Veer
Hi Gaetano,
Thanks for your response. I see what you mean with the pre-processing, but for certain reasons I really want to do the sorting within Paraview if possible.
I tried the sorting sequence you propose but Paraview seems to overwrite previous sorting actions, so the result of sort(z) -> sort(y) -> sort(x) is exactly the same as sort(x) only.
About your second suggestion; I'm not sure if this is a really easy thing to do in Paraview. I will give it a try with programmable Phyton filters, but really hope there is actually an easier way to do so in Paraview. > I tried this using the Calculator filter in Paraview, but this is tricky as there were minor errors in the sorting, leading to a messed up structured grid. I think my values are just to high to use this method (PV cannot handle the 100^3 factor with my numbers).
Thanks, anyway :-)
Ellen
Old   November 6, 2013, 05:20
Ellen van der Veer
I'm still not sure how to solve this problem and I'm actually running out of ideas. Hope someone could help me out another moment. Thanks anyways for your comments .
Old   November 7, 2013, 18:28
Gaetano
I still think that pre-processing would be the best option. A small script will easily do the work, but you might also get it thanks to a programmable filter as first entry in the pipeline, I guess.
I'm not very experienced in that: let's wait for answers from more skilled users
ellenvdveer likes this.
Old   November 9, 2013, 16:41
Bruno Santos
Greetings to all!
@Ellen: Gaetano is right. As someone once said: http://en.wikipedia.org/wiki/Perfect..._enemy_of_good
perfect is the enemy of the good
It's a looooooooot easier to pre-process the data first and then import it to ParaView.
I've spent over 1h trying to learn how to do this in ParaView with the "Programmable Filter" and it's too much trouble to be bothered by it. It requires so many layers of converting data-types, just to get it sorted...
The simplest is to simply load the CSV data onto a numpy table and then use it to sort the table: http://stackoverflow.com/questions/2...umpy-by-column
Then use the numpy converter and send the data to the vtkTable: http://www.paraview.org/Wiki/ParaVie...ammable_Filter - search for "Mixing VTK and NumPy APIs"
All of this would probably have to be done with a "Programmable Source" instead of a "Programmable Filter". But I'm too tired to spend any more time on this
Good luck! Best regards,
Bruno
Old   July 3, 2016, 21:04
Default table to structured grid & whole extent
Ndong-Mefane Stephane Boris
S_teph_2000 is on a distinguished road
could someone explain to me how to determine the "whole extent" for paraview using one of the dataset above?
Steph
S_teph_2000 is offline   Reply With Quote
order, paraview, sort
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 20:06
UDF value to large for defined data type Anna73 Fluent UDF and Scheme Programming 9 September 30, 2018 22:18
[General] problem with extracting data from paraview a.hajisharifi ParaView 5 April 29, 2016 11:38
[OpenFOAM] Paraview: Cell data and Point Data? vitor ParaView 4 May 15, 2015 17:56
XYZ (ASCII format) data points into GAMBIT Neil FLUENT 1 August 7, 2007 09:24
