[General] glyph always has arrows pointing to the x direction
Like Tree3Likes
  • 3 Post By wyldckat
Old   September 18, 2015, 18:08
Default glyph always has arrows pointing to the x direction
youngturtle is on a distinguished road
I am trying to see the flow direction in the model below. When I use glyph arrows to show the flow direction, I always have arrows pointing to the x direction, no matter what solver or parameters I used.
Could anyone help me out? Thank you!
youngturtle is offline   Reply With Quote
Old   September 19, 2015, 05:38
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
With a bit more information about WHAT you are trying to simulate it would be easier to determine what the problem really is. What makes you so sure that velocity vectors with a dominant x-component are actually wrong?
flotus1 is offline   Reply With Quote
Old   September 19, 2015, 11:40
Retired Super Moderator
Bruno Santos
Quick note: When not using the scaling option in the Glyphs filter, ParaView/VTK will use by default the vector "1,0,0" for representing the vectors "0,0,0".
In other words, it's also probable that the magnitude of the represented vectors is actually 0.0.
flotus1, serles and parthigcar like this.
Old   September 23, 2015, 10:55
flotus1's Avatar
Alex
*sigh*
Don't you just hate when this happens
Old   January 28, 2017, 15:39
Default glyph arrows in x-direction
Tom Alderweireldt
Talder is on a distinguished road
I recently installed openfoam 4.1, and just ran the standard elbow tutorial case. Solution and log files look OK. Unexpectedly when testing glyphs with ParaView 5.0.1, all glyph arrows only point in x-direction, whatever I try with the settings.
Any hints would be welcome
Talder
Talder is offline   Reply With Quote
arrow, direction, glyph
[OpenFOAM] Evenly distributed arrows using glyph in ParaView kriz ParaView 4 January 26, 2016 03:23
AutoGrid5: Change direction of a segment David Sauter Fidelity CFD 4 December 14, 2015 03:31
ERROR: Flow direction on the boundaries must not be tangential to the boundary. turbomax CFX 2 August 6, 2015 11:05
[ICEM] How to change the direction of arrows realstoneman ANSYS Meshing & Geometry 0 May 10, 2012 02:19
[OpenFOAM] ParaView Glyph Arrows Outside Vessel slowtype ParaView 0 February 15, 2011 14:01
