Home > Forums > Software User Forums > REEF3D
Error when installing HYPRE (on Windows 10)
Old   May 22, 2021, 06:27
Default Error when installing HYPRE (on Windows 10)
OceanMan
OceanMan is on a distinguished road
Hi, REEF3D team
I have an error when installing hypre-2.11.2.
I did it step by step in the User guide
When I opened ‘Terminal’ and navigate to the “src” folder inside the HYPRE archive and type:
./configure --prefix=/usr/local/hypre.
The error read: "-bash: ./configure: No such file or directory".
Thank you and hope to get some guidance.
NO PAIN NO GAIN
OceanMan is offline   Reply With Quote
Old   May 25, 2021, 04:52
Arun Kamath
kamath is on a distinguished road
Hi OceanMan,
That sounds a little strange.
There could be two reasons:
1. problem with the download- check if the configure script exists in the src folder.
2. the configure script does not have permissions to run. If the file is found (using an ls command to list contents of the folder), then use:
chmod u+x configure
to give it permissions to run.
Arun
X years with REEF3D
kamath is offline   Reply With Quote
Old   May 25, 2021, 06:27
OceanMan
Originally Posted by kamath View Post
Hi OceanMan,
chmod u+x configure
Hi, Kamath
Thanks for your help.
You can see an error in the attachment file.
NO PAIN NO GAIN
Old   May 25, 2021, 07:22
Arun Kamath
Then possibly it is a permissions issue for /usr/local
could you check that?
Arun
X years with REEF3D
Old   May 25, 2021, 14:40
OceanMan
Yes, Thank you so much for helping, sir!
NO PAIN NO GAIN
[Other] How to install OpenFOAM under Windows? lzgwhy OpenFOAM Installation 19 October 7, 2023 04:27
[swak4Foam] Installing swak4foam on OpenFOAM 19.10 (Windows) MCrossover97 OpenFOAM Community Contributions 4 June 21, 2022 05:23
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
[OpenFOAM.com] Installing v1812 on Windows 10 ellen13 OpenFOAM Installation 1 June 18, 2019 16:17
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
