Home > Forums > Software User Forums > REEF3D
Problems compiling DIVEMesh
Like Tree1Likes
  • 1 Post By zweihuehner
Old   November 21, 2021, 20:22
Default Problems compiling DIVEMesh
Faro Schäfer
zweihuehner is on a distinguished road
When trying to compile DIVEMesh with "make j 8" there seems to be a namespace issue in driver.h with 'data'. Thus the compilation can not be completed.
I followed the steps from the installation videos:
sudo apt-get install build-essential gfortran unzip make wget openmpi-bin libopenmpi-dev
mkdir libraries
cd libraries
git clone https://github.com/hypre-space/hypre.git
cd hypre/src
./configure --prefix=/usr/local/hypre
make all
sudo make install
sudo printf '\n#export Path for hypre (part of reef3D) \nPATH=/usr/local/hypre/lib:usr/local/hypre/include:$PATH' >> ~/.bashrc
source ~/.bashrc
cd
git clone https://github.com/REEF3D/DIVEMesh.git
cd DIVEMesh
make -j 8
What am I doing wrong?
**System information:**
- REEF3D 21.10
- DIVEMesh 21.10
- OpenMPI 4.1.o
- Hypre 2.23.0
- OS Ubuntu
Here is the output from the compilation:
In file included from src/driver.cpp:23:
src/driver.h:59:9: error: reference to ‘data’ is ambiguous
59 | data *pdata;
In file included from /usr/include/c++/11/string:54,
from /usr/include/c++/11/bits/locale_classes.h:40,
from /usr/include/c++/11/bits/ios_base.h:41,
from /usr/include/c++/11/ios:42,
from /usr/include/c++/11/ostream:38,
from /usr/include/c++/11/iostream:39,
from src/driver.h:23,
/usr/include/c++/11/bits/range_access.h:319:5: note: candidates are: ‘template<class _Tp> constexpr const _Tp* std::data(std::initializer_list<_Tp>)’
319 | data(initializer_list<_Tp> __il) noexcept
/usr/include/c++/11/bits/range_access.h:310:5: note: ‘template<class _Tp, long unsigned int _Nm> constexpr _Tp* std::data(_Tp (&)[_Nm])’
310 | data(_Tp (&__array)[_Nm]) noexcept
/usr/include/c++/11/bits/range_access.h:300:5: note: ‘template<class _Container> constexpr decltype (__cont.data()) std::data(const _Container&)’
300 | data(const _Container& __cont) noexcept(noexcept(__cont.data()))
/usr/include/c++/11/bits/range_access.h:290:5: note: ‘template<class _Container> constexpr decltype (__cont.data()) std::data(_Container&)’
290 | data(_Container& __cont) noexcept(noexcept(__cont.data()))
In file included from src/driver.h:25,
src/driver_declarations.h:36:7: note: ‘class data’
36 | class objects_geometry;
In file included from src/driver_analytics.cpp:23:
59 | data *pdata;
src/driver.cpp: In member function ‘void driver::mainloop()’:
src/driver.cpp:75:5: error: ‘pdata’ was not declared in this scope; did you mean ‘data’?
75 | pdata->start(p,a);
| data
make: [Makefile:19: build/src/driver.o] Error 1 (ignored)
make: [Makefile:19: build/src/driver_analytics.o] Error 1 (ignored)
In file included from src/main.h:25,
from src/main.cpp:23:
59 | data *pdata;
from src/main.h:24,
from src/main.h:25,
make: [Makefile:19: build/src/main.o] Error 1 (ignored)
In file included from src/logic.cpp:23:
59 | data *pdata;
src/logic.cpp: In member function ‘void driver::logic(lexer*)’:
src/logic.cpp:59:5: error: ‘pdata’ was not declared in this scope; did you mean ‘data’?
59 |
| data
src/logic.cpp:59:17: error: expected type-specifier before ‘data’
59 |
make: [Makefile:19: build/src/logic.o] Error 1 (ignored)
/usr/bin/ld: cannot find build/src/driver_analytics.o: No such file or directory
/usr/bin/ld: cannot find build/src/driver.o: No such file or directory
/usr/bin/ld: cannot find build/src/logic.o: No such file or directory
/usr/bin/ld: cannot find build/src/main.o: No such file or directory
collect2: error: ld returned 1 exit status
make: [Makefile:24: bin/DiveMESH] Error 1 (ignored)
(base) fafs@Fafs-XPS:~/Dev/Reef3D/DIVEMesh$ ll
total 5932
drwxrwxr-x 7 fafs fafs 4096 Nov 21 22:24 ./
drwxrwxr-x 5 fafs fafs 4096 Nov 21 22:01 ../
drwxrwxr-x 2 fafs fafs 4096 Nov 21 22:24 bin/
drwxrwxr-x 3 fafs fafs 4096 Nov 21 22:24 build/
-rw-rw-r-- 1 fafs fafs 5965464 Nov 21 22:01 DIVEMesh-UserGuide.pdf
drwxrwxr-x 8 fafs fafs 4096 Nov 21 22:01 .git/
-rw-rw-r-- 1 fafs fafs 66 Nov 21 22:01 .gitattributes
drwxrwxr-x 3 fafs fafs 4096 Nov 21 22:01 .github/
-rw-rw-r-- 1 fafs fafs 235 Nov 21 22:01 .gitignore
-rw-rw-r-- 1 fafs fafs 35126 Nov 21 22:01 LICENSE
-rw-rw-r-- 1 fafs fafs 14369 Nov 21 22:24 log
-rw-rw-r-- 1 fafs fafs 909 Nov 21 22:01 Makefile
-rwxrwxr-x 1 fafs fafs 2590 Nov 21 22:01 release-notes.txt*
drwxrwxr-x 2 fafs fafs 12288 Nov 21 22:01 src/
(base) fafs@Fafs-XPS:~/Dev/Reef3D/DIVEMesh$ cat log
g++ -w -O3 -march=native -c src/baselayer.cpp -o build/src/baselayer.o
g++ -w -O3 -march=native -c src/bc.cpp -o build/src/bc.o
g++ -w -O3 -march=native -c src/bedlevel.cpp -o build/src/bedlevel.o
g++ -w -O3 -march=native -c src/box_bl.cpp -o build/src/box_bl.o
g++ -w -O3 -march=native -o ./bin/DiveMESH build/src/baselayer.o build/src/bc.o build/src/bedlevel.o build/src/box_bl.o build/src/data.o build/src/data_inversedist.o build/src/decomp_analyse.o build/src/decomp_correction.o build/src/decomp_costfunc.o build/src/decomp_count.o build/src/decomp.o build/src/decomp_paraslice.o build/src/decomp_partition.o build/src/decomp_partition_manual.o build/src/decomp_partition_planes.o build/src/decomp_periodic.o build/src/decomp_periodic_surfco.o build/src/decomp_periodic_surf.o build/src/decomp_print.o build/src/decomp_surface.o build/src/decomp_surfco.o build/src/decomp_vtp.o build/src/dive.o build/src/driver_analytics.o build/src/driver.o build/src/field1d.o build/src/field2d.o build/src/field.o build/src/geodat.o build/src/geodat_holecheck.o build/src/geodat_multigrid_ccipol.o build/src/geodat_multigrid.o build/src/geodat_pointcheck.o build/src/geodat_print-sampled.o build/src/geodat_print-vtp.o build/src/geodat_remove_bounds.o build/src/geodat_setup_ijk.o build/src/geometry_arch.o build/src/geometry_box_array.o build/src/geometry_box.o build/src/geometry_cone_x.o build/src/geometry_cone_y.o build/src/geometry_cone_z.o build/src/geometry.o build/src/geometry_cylinder_y.o build/src/geometry_cylinder_z.o build/src/geometry_ellipsoid.o build/src/geometry_ellipsoid_semi.o build/src/geometry_ellipsoid_semi_rot.o build/src/geometry_fluvial_box_fill_segments.o build/src/geometry_fluvial_box_util.o build/src/geometry_fluvial_box_v1.o build/src/geometry_fluvial_box_v2.o build/src/geometry_hexahedron.o build/src/geometry_jacketmember_norm.o build/src/geometry_ogee-weir.o build/src/geometry_plate_x.o build/src/geometry_pyramid.o build/src/geometry_ray_cast.o build/src/geometry_ray_cast_io_x.o build/src/geometry_ray_cast_io_ycorr.o build/src/geometry_ray_cast_io_zcorr.o build/src/geometry_ray_cast_x.o build/src/geometry_ray_cast_x_gcb.o build/src/geometry_ray_cast_y.o build/src/geometry_ray_cast_z.o build/src/geometry_rotation.o build/src/geometry_semicyl_y.o build/src/geometry_sphere.o build/src/geometry_stl.o build/src/geometry_tetrahedon.o build/src/geometry_wedge.o build/src/geometry_wedge_x.o build/src/geometry_wedge_y.o build/src/geometry_wedge_z.o build/src/hdc_allocate.o build/src/hdc.o build/src/hdc_decomp.o build/src/hdc_filename_in.o build/src/hdc_filename_out.o build/src/hdc_read.o build/src/hdc_read_header.o build/src/hdc_read_mainheader.o build/src/hdc_write.o build/src/hdc_write_header.o build/src/increment.o build/src/ini.o build/src/initialize.o build/src/intfield1d.o build/src/intfield1dy.o build/src/intfield2d.o build/src/intfield.o build/src/inverse_dist.o build/src/inverse_dist_local.o build/src/inverse_dist_local_setup.o build/src/kriging.o build/src/kriging_ini.o build/src/kriging_rearrange.o build/src/kriging_semivariogram.o build/src/kriging_solve.o build/src/lexer.o build/src/lexer_createspace.o build/src/lexer_gridspacing_cellBased.o build/src/lexer_gridspacing.o build/src/lexer_gridspacing_fsf.o build/src/lexer_gridspacing_print.o build/src/lexer_pos.o build/src/logic.o build/src/main.o build/src/module_void.o build/src/print_binary.o build/src/print_bottom.o build/src/print_debug.o build/src/print_solid.o build/src/print_vtu.o build/src/read_control.o build/src/read_data.o build/src/read_geodat.o build/src/read_solid.o build/src/read_stl.o build/src/read_topo.o build/src/resize.o build/src/resize_delete.o build/src/resize_resize.o build/src/slice.o build/src/solid.o build/src/solid_fluvial_box.o build/src/surface.o build/src/surface_dir.o build/src/surface_plate.o build/src/surface_solid.o build/src/topo.o
Last edited by zweihuehner; November 21, 2021 at 20:39. Reason: question wasn't finished
zweihuehner is offline   Reply With Quote
Old   November 22, 2021, 08:00
Arun Kamath
kamath is on a distinguished road
Seems like a compiler issue on your local machine.
DiveMESH uses only g++ and has no dependencies. So problems compiling this are quite rare (and therefore I haven't seen a lot a problems) and generally compiler related.
Could you please post the output you get for:
which gcc
which g++
What I also find strange is that while you get an error during the compilation (from the first console output pasted above), the output that denotes the making of the executable is printed out in full (the last output).
Arun
X years with REEF3D
kamath is offline   Reply With Quote
Old   November 22, 2021, 08:19
Faro Schäfer
Thank you for the quick reply.
which gcc
usr/bin/gcc
gcc -dumpfullversion
11.2.0
which g++
usr/bin/g++
g++ -dumpfullversion
11.2.0
Is the executable output actually correct ? Shouldn't it end with
-o DiveMESH
Old   November 22, 2021, 08:37
Arun Kamath
The last quote in your original post is correct.
Starts with
g++ -w -O3 -march=native -o ./bin/DiveMESH ...
ends with build/src/topo.o
as expected.
Could you please confirm that the DIVEMesh/bin folder is actually empty?
Meanwhile I will check if there are any issues with gcc-11
Arun
X years with REEF3D
Old   November 22, 2021, 08:54
Faro Schäfer
DIVEMesh/bin is empty.
And I am very sorry there is also output at the very end:
... o build/src/surface_solid.o build/src/topo.o
I checked and those files don't exist.
I forgot to quote it as the maximum number of letters was exceeded.
Old   November 22, 2021, 08:57
Arun Kamath
No problem
But I can at this stage confirm that compiling fails with gcc-11.
We are looking into it and a fix might come soon.
In the meantime, as a temp fix:
sudo update-alternatives --remove-all gcc
sudo update-alternatives --remove-all g++
sudo apt-get install gcc-9.3.0 g++-9.3.0
should help?
(This is the highest version I have confirmation currently for a successful compilation on a Linux machine)
Arun
X years with REEF3D
Last edited by kamath; November 22, 2021 at 08:58. Reason: command to remove gcc before installing new versions added
Old   November 22, 2021, 09:34
Faro Schäfer
Compiles beautifully now!
Your recommended commands didn't work for me, however I did the following instead:
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt update
sudo apt install g++-9 gcc-9
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-9 60 --slave /usr/bin/g++ g++ /usr/bin/g++-9
sudo update-alternatives --config gcc
Versions are now both 9.4.0.
kamath likes this.
Old   November 23, 2021, 07:19
Hans Bihs
valgrinda is on a distinguished road
Should be fixed in the newest DIVMesh release candidate, should be now compatible with gcc v11.
Hans Bihs
Team REEF3D
www.reef3d.com
valgrinda is offline   Reply With Quote
Old   November 23, 2021, 09:28
Faro Schäfer
Thanks a lot !
divemesh
Various problems compiling interFoam with CFDSupport's v1706 port of OpenFOAM ndtrong OpenFOAM Programming & Development 9 April 10, 2020 11:56
[OpenFOAM.org] Problems with Compiling OpenFOAM-2.1.1 in Ubuntu 16.04 charles4allme OpenFOAM Installation 17 May 31, 2018 09:01
[waves2Foam] Problems compiling with Ubuntu 14.04 and OpenFOAM 3.0.1 kenrichaiz OpenFOAM Community Contributions 4 December 1, 2016 03:05
Problems while compiling OpenFOAM15 with OpenSuse 103 coompressor OpenFOAM Installation 3 November 7, 2008 00:57
Problems with compiling CFD code! ravi Main CFD Forum 1 July 12, 2004 11:28
